ᐅ Are there child-friendly versions of Ikea PLATSA?
Created on: 28 May 2019 14:23
sinmu3
sinmu3
28 May 2019 14:23
I am currently considering using the Ikea PLATSA system for a children's room. My specific question is: Are there child-friendly versions of Ikea PLATSA, meaning solutions or modifications designed specifically to meet the needs and safety of children? I am thinking of age-appropriate heights, safe materials, rounded edges, or modular concepts that grow with the child and offer versatile use. Does anyone have experience with this or know of examples where PLATSA has been adapted to make it truly child-friendly? Thanks in advance!
Renegi
28 May 2019 14:45
PLATSA itself is modular, but Ikea does not offer a specific "children’s version."
One approach is to choose low modules and install them with soft edges or protective profiles. Safety locks and child-friendly handles can be added additionally.
praWarre69
28 May 2019 15:12
Cool question! 😄 PLATSA can be customized very individually – of course, the original design is more functional. For kids’ rooms, I recommend colorful fronts and easy-to-grip knobs that can be screwed on easily. A mix of open and closed compartments is also practical, so everything can be easily accessible in a playful way. And yes, if you want it really child-friendly, go for padding on the corners – like a little playground at home! 🚀
glapu
28 May 2019 15:37
Simply build some PLATSA modules lower, then children can easily reach everything.
Secure edges with suitable protective strips; that is often sufficient.
sinmu3
28 May 2019 16:03
Thanks for the assessment. It is clearly not directly marketed as a children’s solution, hence my question about the best possible adaptations.
praWarre69 schrieb:
A mix of open and closed compartments is also practical, so that everything can be accessible for playful use.
I find the point about open compartments stimulating childlike curiosity interesting. However, I have concerns about dust and keeping things tidy. How do you manage this in practice, especially with small children?
glapu schrieb:
Securing edges with suitable protective strips is often enough.
Are there specific recommendations that fit well with the PLATSA dimensions? I want to avoid too much DIY work if possible.
LUSAR
28 May 2019 16:31
From a technical and safety perspective, the following points should be considered for children's bedroom furniture:
- Adjust the minimum height of the units according to the child’s age to minimize climbing hazards
- Use non-toxic, certified low-emission materials (PLATSA uses MDF with melamine coating, which is relatively safe)
- Secure furniture to the wall to prevent tipping
- Edges should be rounded or fitted with special protective profiles, preferably shock-absorbing
For specific protective strips, it is recommended to look for universal soft plastic edge guards for furniture, which can be cut to size and attached with adhesive tape or screws. Since PLATSA units have standardized dimensions, rough adjustments are usually sufficient.
