ᐅ Are there versions of the Billy bookshelf with improved climate resistance?
Created on: 22 Jun 2017 08:43
Rosa8
Good morning everyone,
I am currently looking into whether there are different versions of the IKEA Billy bookcase that are specifically designed to withstand varying climate conditions. The reason is that I plan to place a Billy bookcase in a rather damp and changeable room, where temperature and humidity levels fluctuate significantly.
Specifically, I am interested in whether IKEA or other suppliers offer versions of the Billy bookcase or similar shelving systems that use special finishes, materials, or manufacturing techniques to be less prone to mold, swelling, or warping due to moisture.
Maybe someone has experience with this topic or knows of alternatives that are fundamentally similar but more durable under such climate conditions? I look forward to your feedback!
Interesting thread!
However, I question whether focusing on the "climate resistance" of the Billy shelf is really meaningful, considering that its design and materials are intended for living spaces where humidity is not consistently high.
Exactly. Instead of focusing on versions that don’t exist, it might be better to reconsider the basic assumptions about the location and use.
Is the room ventilated? Will the furniture be constantly wet or damp? These are factors that matter more than "optimizing" the Billy shelf.
Without structural changes to the environment, the best solution may be to look for alternative furniture.
REN40 schrieb:
If the Billy shelf is to be used in damp rooms, I recommend models made of metal or specially treated wood products.
neo59 schrieb:
However, I question whether focusing on "climate resistance" for the Billy bookshelf really makes sense, considering that the design and materials are intended for indoor living spaces.Thanks, that’s a good point! I’d like to add that although the room is heated, there are often significant fluctuations in humidity, especially in winter when the room is ventilated.
Therefore, I am not looking for furniture suitable for permanently damp conditions, but rather for a less-than-ideal room with occasional exposure.
The question was whether there are modified or officially offered versions of the bookshelf itself, or if I should focus on other products instead.
Perhaps someone has experience with DIY solutions that provide additional protection afterward?
Great that you clarified this again, Rosa8!
In your case, I definitely recommend sealing the cut edges properly. Often, the edges of the Billy shelf are only covered with a thin coating that easily absorbs moisture.
You can paint the edges with a simple wood varnish or acrylic paint (water-based), which greatly reduces moisture absorption!
Another tip is to use small furniture feet or spacers to lift the shelf off the floor, preventing moisture from accumulating underneath. This makes the shelf much more durable—I have successfully tested this myself!
It’s really clever when you pay attention to these little tricks! :-)
Hey everyone, here are a few tips from me as well!
In addition to the already mentioned joint sealants, water-repellent treatments can also be useful, which you can apply to the shelf. Just make sure that the treatment does not change the appearance of the shelf or leave a sticky residue.
Also, ensure good air circulation around the shelf to prevent moisture buildup.
Exactly! I also use small felt or rubber pads underneath to protect the floor and allow air to flow. It really works great! 😊
Teonon schrieb:
Another trick is to use small furniture feet or spacers
Garth49 schrieb:
In addition to the aforementioned joint sealants, water-repellent impregnations can also be usefulI agree with this. It is important that impregnations are suitable for furniture, so that the coating remains breathable and does not cause bubbles or damage to the melamine.
Although edges and corners are the main areas prone to moisture damage, I recommend regular inspection and immediate local treatment at the first signs of issues.
Additionally, the shelf should not be placed directly next to radiators or on cold walls to avoid condensation.
I appreciate that practical solutions are the main focus here. However, I would like to point out that DIY sealants and impregnations also carry certain risks:
If they are not applied properly, moisture absorption can actually increase because moisture can get trapped under the sealant (capillary effect).
Therefore, the material should be thoroughly dried before sealing and checked carefully to ensure there is no remaining moisture.
From environmental and health perspectives, I also recommend using products that are as odorless and low-emission as possible.
