ᐅ Are there versions of the Billy bookshelf with improved climate resistance?
Created on: 22 Jun 2017 08:43
Rosa8
Rosa8
22 Jun 2017 08:43
Good morning everyone,
I am currently looking into whether there are different versions of the IKEA Billy bookcase that are specifically designed to withstand varying climate conditions. The reason is that I plan to place a Billy bookcase in a rather damp and changeable room, where temperature and humidity levels fluctuate significantly.
Specifically, I am interested in whether IKEA or other suppliers offer versions of the Billy bookcase or similar shelving systems that use special finishes, materials, or manufacturing techniques to be less prone to mold, swelling, or warping due to moisture.
Maybe someone has experience with this topic or knows of alternatives that are fundamentally similar but more durable under such climate conditions? I look forward to your feedback!
Teonon
22 Jun 2017 09:11
Hey Rosa8, it’s great that you’re doing such thorough research! 😊
Regarding your question: As far as I know, IKEA only offers the Billy bookshelf in a standard version made of particleboard with a melamine finish, which isn’t necessarily known for high moisture resistance. However, the melamine coating is quite durable against humidity as long as it isn’t mechanically damaged.
I have a Billy in my basement myself, and it has held up well so far, but of course, this depends on how it’s used and the humidity levels. 😉
There are definitely some DIY methods to better protect the shelf with additional sealing or paint! Maybe someone else will chime in with more detailed advice!
mifra
22 Jun 2017 09:37
For clarification: The classic Billy bookshelf from IKEA is typically made of particleboard with a melamine resin coating. This coating provides some resistance to moisture, but the material as a whole is not designed for high or consistently high moisture exposure.
I am not aware of any official variants from IKEA with improved climate resistance.
For higher moisture protection requirements, it is recommended to use shelves made of MDF with special impregnations, solid wood with oiled surfaces, or metal shelving.
Alternatively, there are also specialized furniture options available for outdoor or damp environments that feature waterproof edging and coatings.
There are no officially offered "Billy variants" from IKEA with better climate resistance, except possibly new lacquer or paint versions, which generally do not provide increased moisture protection.
RON57
22 Jun 2017 10:04
Hello Rosa8,
I can only agree with mifra regarding the lack of official variants with better climate resistance.
However, I would like to add that the Billy shelf can definitely be modified if you are skilled in DIY. For example, sanding and resealing the edges with waterproof varnishes can make the shelf quite robust against moisture absorption.
Also, applying silicone at the joints or using spacers to distance the shelf from the wall can help reduce moisture issues.
For rooms with very high humidity, however, other types of shelves are more suitable.
tabau70
22 Jun 2017 10:26
Great question, Rosa8! 😊
I have my Billy bookshelf in my hobby basement, where it often gets damp in winter. Since I started protecting the edges with clear varnish, the shelf feels much more durable!
mifra schrieb:
There are no officially offered Billy variants from IKEA with improved climate resistance
I agree with that. IKEA doesn’t seem to have designed it specifically for this, but with some simple tricks you can get a lot out of it!
If you want, you can also consider white shelves – the coating is said to be similar, but the thickness can vary, and sometimes that helps a bit against moisture absorption.
REN40
22 Jun 2017 11:02
Based on my experience, there are no versions of the Billy shelf from IKEA that are specifically labeled as "climate-resistant."
It is important to keep humidity as low as possible, or at least to provide the furniture with a stable environment.
If the Billy shelf is to be used in damp areas, I recommend models made of metal or specially treated wood products.
This also has a positive effect on durability and maintaining value. I would advise against modifying the furniture yourself, as improper treatment can delay or void the warranty.
