ᐅ Are there better replacement handles for Malm dressers?
Created on: 13 Nov 2017 19:03
jerome34
jerome34
13 Nov 2017 19:03
Hello community,
I have a Malm dresser from Ikea that I really like, but I find the original handles a bit too simple and they look quite cheap to me. Therefore, I’m considering whether there are better replacement handles that are more sturdy, look higher quality, and still fit well.
My specific question is: Are there any recommended alternatives to the original Malm handles that can be easily retrofitted? It is important to me that the dimensions match or that the installation is straightforward without having to drill unnecessarily large holes in the front. I would also like to know which materials or designs are especially suitable to give the furniture a more elegant appearance.
Maybe someone already has experience with other handles or can recommend manufacturers/models that fit perfectly with Malm dressers? I look forward to your tips and advice!
jakob70
13 Nov 2017 19:45
If you are looking for sturdy handles, check out Möbelgriff24 or Amazon for metal handles. Important: Pay attention to the hole spacing, usually 128 mm (5 inches) for Malm. Stainless steel or brushed metal often works well.
Sepele
13 Nov 2017 21:30
Hello Jerome,
regarding your question about better replacement handles: The Malm dresser, as Jakob has already mentioned, usually has a hole spacing of 128 millimeters (5 inches). This is important because handles with this measurement fit directly without major modifications.
Tip: Instead of using cheap plastic handles, you can opt for metal handles made of aluminum or stainless steel. These not only feel more durable but also look more refined.
A common mistake is not checking the measurements properly. Make sure to measure the "center-to-center" distance of the holes precisely; otherwise, the handle will not fit correctly.
Another tip: Many manufacturers also offer curved handles with this standard spacing, which can give your dresser a more modern look immediately.
In summary: When choosing handles, rely on the exact hole spacing, material quality, and design to ensure the handle lasts long and looks good.
lideo
13 Nov 2017 22:17
Alternative: Solid wood handles also look good and are sturdy. The important thing is to make sure the drill holes are precisely aligned. Otherwise, you can often find such handles at hardware stores.
jerome34
14 Nov 2017 08:10
Thanks for the quick responses so far!
Could you briefly explain how to measure this hole spacing accurately? I want to be sure before ordering handles.
Also, I’m interested if anyone has experience with handles made of brass or copper? That would hopefully provide a nice contrast to the white Malm.
Sepele
14 Nov 2017 09:38
Gladly!
The hole spacing is measured from the center of the first screw hole to the center of the second screw hole, horizontally in a straight line. The easiest way is to use a ruler or tape measure to find the center of the left hole (look down, the holes are often visible) and then measure horizontally to the second one.
Regarding brass or copper: These metals offer a warm color and are quite durable. However, brass can tarnish over time and develop a patina, which changes the appearance somewhat. Copper is similar. If you like a vintage look, these are nice options. For a longer-lasting shiny finish, you will need to polish regularly.
Summary:
1. Measure the hole spacing precisely at the existing holes.
2. If you choose brass/copper, be prepared for maintenance.
3. Alternatively, there are also powder-coated handles that require less upkeep.
