ᐅ Are there any assembly tips that can speed up putting together IKEA Hemnes furniture?
Created on: 6 Nov 2019 09:23
Tigoki
Tigoki
6 Nov 2019 09:23
I’m about to assemble an IKEA Hemnes wardrobe and was wondering if there are any special assembly tips or helpful techniques that can significantly speed up the process.
My goal is not only to save time but also to avoid common mistakes and achieve a stable and neat final result.
Does anyone have experience with the Hemnes system? Maybe you know of clever shortcuts, prepared tool setups, or an effective order of steps that makes the assembly more efficient? I’d appreciate any practical advice or tips that go beyond the standard instructions!
Thanks in advance!
Z
zartra
6 Nov 2019 10:12
Before starting assembly, be sure to sort all the parts and read the instructions carefully. Then, have all screws and anchors ready at hand.
A cordless drill with torque control is invaluable and saves a lot of time.
It also helps to assemble the furniture on a soft surface to avoid scratches.
fepau
6 Nov 2019 12:45
Oh yes, I love the Hemnes! 😄 My advice: It’s best to ask a friend for help because working together is much faster and more enjoyable!
Also, it’s better to take it step by step and not rush – otherwise, details can easily be overlooked.
And very important: Be proud of what you have accomplished so far from time to time; that’s really motivating! Good luck!
O
olivernu
7 Nov 2019 08:57
zartra schrieb:
A cordless screwdriver with torque control is worth its weight in gold and saves a lot of time.
That is definitely a key point. Additionally, I recommend carefully checking all wooden parts for damage and fit before assembly. This significantly reduces delays later on.
Another strategy is to start fastening screws lightly before fully tightening them once all parts are properly aligned. This prevents stress and makes adjustments easier.
Furthermore, I prefer assembling furniture in reverse order – first putting together the larger parts, then the smaller components. This way you maintain an overview and avoid clutter in tight spaces.
Nicksin
7 Nov 2019 13:33
Tigoki schrieb:
Does anyone have experience with the Hemnes system? Maybe you know some smart shortcuts, a prepared tool setup, or an efficient order of tasks that makes the process easier?
Hey, sure! My favorite trick is what I call "pre-assembly in stages." Basically, you create mini-modules like doors, shelves, and similar parts separately – this saves a lot of time and hassle when you put everything together later.
Also: Try reading the instructions in chunks, not just straight through from start to finish – this helps avoid surprises.
One more thing: Keep a box reserved for screws and small parts while you work, so you can always find everything right away. It sounds simple, but it really cuts down on constant searching. Have fun with the assembly! 😎
