ᐅ Are there any assembly tips for connecting multiple IKEA PLATSA units?
Created on: 27 Jul 2021 14:22
Behzat
I am planning to combine several IKEA Platsa modules to create a larger, custom-made wardrobe system. Since I am mostly following the instructions for individual modules, I wanted to ask if anyone has assembly tips or practical advice on how to connect the different PLATSA modules in a stable, secure, and visually appealing way. Especially important to me is what to pay attention to when joining the modules regarding anchoring, alignment, and possible reinforcements beyond the standard instructions.
I would appreciate concrete tips, preferably from personal experience, that can help me make the assembly process as smooth as possible.
gadalu
28 Jul 2021 09:02
Regarding your specific setup with two modules 100cm (39 inches) high and one module 64cm (25 inches) high placed side by side:
- Anchoring: Make sure to fasten all three modules parallel to the wall. The upper anchor points should ideally be installed continuously at the same height.
- Appearance: The different heights naturally create a step; to make the front look more uniform, you can, for example, add a cover panel to the lower module or plan the whole as a stepped design.
- Connection: Use the supplied metal connectors between the modules. If the floor surface is uneven, use shims or wedges to ensure all modules stand level.
- Check gaps: Before screwing, open and close each door individually to ensure the gaps are even.
In short: focus on precise alignment, even fastening, and thorough checking when connecting.
benfa
28 Jul 2021 10:27
Behzat schrieb:
Are there any special considerations I should keep in mind at the connection points to avoid gaps?
This is a point I would like to question: How important is visual perfection to you compared to functional stability?
- Gaps can occur due to manufacturing tolerances and uneven floors. Compensating for these sometimes requires elaborate measures such as custom-cut trims or adjustments at the connection points.
- One could argue that slight gaps in modular systems are normal, and most users hardly notice the difference as long as stability is ensured.
I recommend creating a detailed tolerance plan before installation and, if necessary, checking whether edge refinements or recess adjustments on the modules are needed.
It would also be interesting to discuss how much effort should realistically go into DIY projects like this without losing sight of the primary purpose.
TAUPLO
28 Jul 2021 11:40
Hey Behzat & Co,
I assembled a very similar setup about six months ago and can only say: patience is key! 😊
- Take plenty of time to build the modules and make breaks in between. This helps keep your nerves calm and makes the whole process more enjoyable.
- If you notice that a part is sticking or the connection doesn’t fit perfectly, don’t force it—better to step back a bit and check the alignment again.
- For the look, I added black felt pads under the system; these small helpers make a difference with slight floor unevenness and also protect the floor surface.
- And very important: treat the assembly as your own little project that brings you joy—the Platsa modules are so flexible that minor unevenness is part of their charm.
Keep it simple and enjoy!
Sebastianm
28 Jul 2021 12:53
a quick addition: When connecting multiple PLATSA modules, it is advisable not to fully tighten the connection screws right away. This way, you can still make small adjustments later to correct any gaps. Only tighten all the screws firmly once everything fits perfectly.
