ᐅ Are there any common installation mistakes to avoid when assembling the Ikea Hemnes furniture?
Created on: 22 Aug 2023 19:23
soonfo
soonfo
22 Aug 2023 19:23
I recently started assembling an IKEA Hemnes piece of furniture and noticed that some assembly steps can be quite critical if you’re not careful. Therefore, I’m interested in knowing: Are there specific assembly mistakes to definitely avoid when putting together IKEA Hemnes? I’m thinking of common pitfalls or errors that are difficult to fix later and could affect stability or appearance. Who has experience with Hemnes and can share tips on mistakes to avoid and recommended approaches?
EDWARD0
22 Aug 2023 19:47
It is important to follow the instructions carefully and step by step. With Hemnes, the most common mistake is the incorrect orientation of the screws, which results in loose connections. Also, be sure to ensure that all wooden parts are properly aligned before fastening them securely.
PLOMA
23 Aug 2023 08:11
soonfo schrieb:
Are there specific assembly mistakes that should definitely be avoided when putting together the IKEA Hemnes?
The Hemnes frame is made up of many pre-fabricated wooden parts that must fit together precisely. A common mistake is careless pre-drilling or screwing in the wooden connectors without proper alignment. I recommend first fitting the parts together gently without applying force to check the fit before fully driving in the screws.
Additionally, it is important not to attach the back panel too early or too tightly. Doing so can quickly distort the corners of the frame, which later causes problems with closing the doors or drawers. Overall, I advise tightening the screws only by hand initially and then securing them gradually using a torque tool.
The small dowels should not be underestimated either, as they are easily missed or positioned incorrectly. These details significantly affect both stability and the neat appearance.
Have you experienced difficulties with any particular assembly steps? I’m especially interested in whether the fittings could always be installed without damage in your experience.
Josefane
23 Aug 2023 12:56
EDWARD0 schrieb:
It is important to follow the instructions carefully, step by step.
I also approach this point with some skepticism. Of course, the instructions serve as a blueprint, but experience shows that they do not necessarily cover every detail, such as how much pressure to apply to the wooden parts or when it might be better to temporarily fix parts rather than screwing them in. Simply following the sequence does not always prevent errors caused by misaligned components.
Furthermore, I wonder if there are avoidable assembly errors with the Hemnes furniture that are systemic in nature, for example due to imprecise fittings or pre-cut screw lengths. Each assembly is unique, but wouldn’t it also be useful to know which errors occur more frequently because the design itself does not allow enough tolerance?
Who can share insights or even provide evidence on this? For instance, from personal experience with defective or unstable furniture after assembly?
