ᐅ Are there building instructions available for repairing IKEA BRIMNES drawers?
Created on: 6 Jan 2017 09:17
Baukirill
I have a specific question about repairing IKEA Brimnes drawers: Is there anywhere to find detailed construction instructions or step-by-step repair guides specifically focused on the mechanics and assembly of the drawers of this model?
I am mainly interested in fixing the drawers myself, as some of them stick or have slightly damaged sliding rails. I’m looking for help not only with disassembly but also with renewing sliding rails, screws, or targeted troubleshooting for warped parts.
Does anyone have experience or perhaps printed or digital guides that specifically cover these aspects?
Thanks in advance for your support!
Baukirill
7 Jan 2017 08:11
ronAlberto schrieb:
What kind of damage are you specifically experiencing with your BRIMNES drawers? Do they stick in a certain position or are parts broken?
Thanks for asking! The issues with my drawers mainly involve two points:
- First: On some of the slides, the small plastic rollers are either worn out or occasionally break off when pulling the drawers out, causing them to stick.
- Second: Some of the metal rails appear slightly bent, which slows down the smooth sliding of the drawer.
I don’t want to replace entire drawers immediately, but rather optimize or replace the roller parts and slides selectively. However, I haven’t found any repair-specific manuals online so far.
Does anyone perhaps know detailed repair guides that, for example, provide step-by-step instructions on how to replace these plastic rollers or how to properly realign bent slides?
GU-LAU60
7 Jan 2017 09:30
You can usually replace the plastic rollers easily if you fully remove the drawer. To do this, you may need to partially loosen the guide rail.
Bent metal guides should be carefully reshaped using pliers or a similar tool. Be careful not to break anything.
dabasi
7 Jan 2017 10:00
Baukirill schrieb:
Does anyone perhaps have detailed repair guides that, for example, describe step-by-step how to replace these plastic rollers or how to readjust bent sliding tracks?
Oh yes, I’m familiar with that from my Brimnes drawers! 😊
My tips:
- Unscrew the drawer and lay it flat on the floor
- Carefully pull out the tracks; they are often secured with small metal clips
- You can simply pull the rollers forward out and insert the replacement part
- If the tracks are bent, gently bend them back to their original shape by hand, making small adjustments gradually
I’ve done this myself several times and it works really well, even without an official guide. If you want, just take it step by step—you’ll definitely manage!
Genuan
7 Jan 2017 11:15
For a repair guide for BRIMNES drawers: There is no official one. Simply remove the drawers, clean or replace the rails, and replace the rollers.
Carefully straighten any bent rails. Spare parts are often available through IKEA.
