ᐅ Are there construction guides available for customized Ikea PLATSA solutions?
Created on: 29 Jun 2021 18:37
MarioHello everyone, I am currently working on planning a custom solution using the Ikea Platsa system, and I have the following question: Are there any assembly guides or instructions in a broader sense that specifically address custom-made or self-designed configurations of Ikea PLATSA? I am particularly interested in how to create precise constructions for rooms with unusual dimensions or special requirements without relying solely on the official Ikea planning tools. Does anyone know of detailed guides, tips, or resources that help to build custom PLATSA furniture safely and securely? Thank you in advance for your experiences and suggestions!
GUSTAVO5629 Jun 2021 19:04Hello Mario, I would like to contribute to your detailed question, as I have been working with custom furniture planning, including PLATSA, for some time. Basically, Ikea itself only offers the official planning tool, which is mainly designed for the standard modules and their combinations. However, you can find very detailed guides in various community forums or blogs on how to customize PLATSA modules, such as by modifying shelves, adding extra reinforcements, or combining them with other furniture parts.
The advantage of these building guides is that they often address the issues step by step, for example, how to strengthen stability in tall cabinets, which screws to use, or tips for wall mounting on uneven walls. My advice would be to specifically search these sources for your exact measurements and requirements.
To help you better: What does your room look like? Are there any particular challenges, such as sloped ceilings, uneven floors, or very specific dimensions? These factors can greatly affect the choice of components and stabilization.
GUSTAVO56 schrieb:
What does your room look like? Are there any specific challenges, like sloped ceilings, uneven floors, or very unusual dimensions?I also find this point very important! 😉 The PLATSA systems are great, but once you want to go beyond the standard dimensions, it can get tricky. Assembly guides aimed at custom solutions usually come from hobbyists or DIY enthusiasts sharing their experiences—and a lot of trial and error is involved.
Sometimes it also makes sense to work with simple additional parts from a hardware store to modify PLATSA when the manufacturer doesn’t offer enough flexibility. So it’s better not to see the more complex assembly instructions as rigid rules but rather as sources of ideas and practical tips.
What I mean is: there are no official, detailed plans for custom PLATSA modules—but with creativity and good advice, it usually works out quite well. 😊
Mario schrieb:
Are there any building instructions or guides in a broad sense that specifically address custom-made or self-designed combinations of Ikea PLATSA?From my perspective, the short answer is: No, there are no official Ikea assembly instructions that cover customized PLATSA solutions beyond the standard modules. These combinations are simply not intended by the manufacturer.
However, this does not mean that no support exists. Rather, private guides, forum posts, or video tutorials from the DIY community are currently the main sources for such individual projects.
If you plan custom constructions with PLATSA, you should particularly consider the following factors:
- Load-bearing capacity of each module and their connection points
- The need for additional stabilization through wall attachments
- Adjustments for unusual wall dimensions or ceiling heights
- Use of supplementary components (e.g., braces, extra supports)
To avoid stability issues in your project, a detailed plan with on-site measurements is recommended, as well as possibly simulating or simplifying construction steps. If you provide more detailed information about your project, the community can certainly offer more targeted help.
