Hello everyone, I am currently planning to assemble several Billy bookshelves from IKEA in my apartment and have noticed that the assembly can be quite time-consuming and sometimes a bit frustrating due to the many individual parts and screws. Since I want to avoid spending too much time on the instructions and sorting the parts, I’m wondering: Are there any proven tips or methods to simplify the assembly of Billy shelves that not only save time but also help ensure everything is stable and properly aligned in the end? I look forward to your advice, experiences, or maybe even special tools that could make the process easier. Thanks in advance!
NARPLO schrieb:
Could you possibly share some insights about back panels? Is it better to install them at the very end or during the assembly process?The back panel should definitely be installed at the end. It acts as a diagonal brace that provides the shelf with the necessary stability. Installing it too early can cause fitting issues if the shelf still needs to be adjusted for alignment.
Another tip: You can carefully fix the screws for the shelves with a bit of assembly adhesive. This will prevent them from loosening over time. The adhesive doesn’t harm the shelf and can be temporarily removed if something needs to be replaced.
I also recommend using a small spirit level during assembly to ensure everything is perfectly straight when setting it up.
Hello! 🙂 I tried a little lifehack: Just time yourself assembling the first shelf, then optimize the whole process for the next one—like sorting screws, preparing the assembly surface, and so on. This way, building the second and third shelves becomes much more relaxed and even really enjoyable!
Also: If you’re a bit creative, you can fit the bottom shelves with non-slip felt pads to prevent the shelf from sticking to the floor when it needs to be moved.
Sounds simple, but it really helps 😄
NARPLO schrieb:
Are there any proven tips or methods to make assembling BILLY shelves easier, not only saving time but also ensuring everything ends up stable and neatly aligned?I like to take this as a little lighthearted call for advice: every tip counts, and for me, assembling with friends or family has been helpful. It not only makes the process easier but also turns it into a pleasant event. Teamwork is fun and helps everyone keep track of what’s going on!
Rashadmeo16 Dec 2022 10:09One extra tip from me: Patience is key! 🙂 If something doesn’t work right away, it’s better to step back and take a closer look rather than forcing it!
I think that’s awesome, I’ll try it on my next furniture project. Thanks for the tips, everyone – tricks like these really make assembly more enjoyable and faster, guaranteed!
TEOZAR schrieb:
A bit of wax (preferably candle wax) can prevent the parts from sticking or rubbing against each other
