ᐅ Are there any tips for keeping IKEA BESTA doors consistently tight and aligned?
Created on: 7 Dec 2019 14:23
barno
barno
7 Dec 2019 14:23
I currently have several IKEA BESTÅ cabinets in my living room, but with almost all the doors, I notice that after some time they no longer stay properly aligned under tension. This causes the doors to no longer close cleanly or to hang slightly, and eventually an unpleasant rattling develops.
I know the assembly instructions offer adjustment options for the hinges, but apparently, these are not always effective in the long term. Therefore, my question is whether anyone in this forum knows tricks or methods to keep the doors of the IKEA BESTÅ cabinets properly tensioned permanently?
Ideally, I’m looking for tips not only on better installation but also on preventing material warping or sagging caused by material stress over time.
Thanks in advance for your ideas and experiences!
Ryker66
7 Dec 2019 14:45
The best method is to regularly adjust the hinges.
You can also attach thin plastic or felt strips to the inside edge of the door to increase pressure without overtightening.
Most of the time, the issue is that the cabinet is not standing completely level.
PLOMA
7 Dec 2019 16:02
Hello barno,
I’ll go a bit deeper into the topic because the issue with BESTÅ doors is not uncommon but can be effectively addressed.
Background: The door material is usually a mix of MDF or particleboard with foil or laminate coating. These tend to warp slightly due to fluctuations in humidity, which, combined with the simple and inexpensive hinge design, leads to the stress problems mentioned.
What you can do to keep the doors properly tensioned over time can be summarized as follows:
- Precise cabinet alignment: Use a spirit level to check all dimensions of the cabinet, especially the flatness of the base and the vertical alignment of the side panels. Even slight deviations cause uneven forces on the door.
- Hinges: IKEA hinges are adjustable, but some users replace them with high-quality, self-adjusting furniture hinges that offer better stability and accessibility.
- Reinforcement: Narrow reinforcing strips made of wood or aluminum can be glued to the slim edges of the doors to prevent warping.
- Material protection: Some form of ventilation or humidity regulation helps, as fluctuations in indoor climate are the main cause of warping.
Another tip is to regularly lubricate the hinges and possibly use slightly firmer dampers or bumpers to relieve stress on the hinges.
I’m curious: Are your doors veneer-coated or foil-coated? And do you feel the floor gives way at all when you move the cabinet?
barno
8 Dec 2019 09:18
PLOMA schrieb:
Another tip is to regularly lubricate the hinges and possibly use firmer dampers or buffers to relieve stress on the hinges.
Thanks in advance for the detailed feedback. To answer your questions: The doors have a foil or laminate surface, not veneer. And yes, the floor is not perfectly level, but I installed adjustable pads under the feet of the BESTÅ units, which allow for surprisingly precise leveling. Still, I feel that over a longer period the cabinet elements might settle or loosen slightly.
The idea of using firmer buffers sounds interesting; I haven’t tried that yet. Is there anything specific you would recommend?
So far, I haven’t adjusted the hinges often, as I thought the initial installation would cover most of it. Maybe I should make that a regular routine.
Scarlett
8 Dec 2019 10:57
I think it’s great that this topic is being discussed so openly because I also often have issues with the BESTÅ doors. It’s really frustrating when something doesn’t close properly and you constantly have to adjust it.
Sometimes it almost feels like the cabinet is “walking away” from you – I don’t know if others experience this too?
I’ve also considered whether attaching small rubber buffers to the frame to hold the doors more firmly, or even adding thin neoprene strips inside, might help prevent the doors from sagging so much. At least that helped me a little.
I’m curious to see what other tips come up here, as I don’t regularly adjust the doors myself, which is probably a mistake.
