ᐅ Are there any tips for cleaning IKEA HEMNES furniture more quickly?
Created on: 12 Mar 2024 08:23
nycolas
nycolas
12 Mar 2024 08:23
I recently purchased several IKEA Hemnes furniture pieces (dresser, nightstand, and TV stand) and I’m wondering if there are any tips or best practices to make cleaning these pieces faster and more efficient. The surface is lacquered, so I want to avoid damaging the furniture with the wrong cleaning products or methods. Does anyone have recommendations for the best cleaning agents or tools that save time while protecting the finish? Suggestions on how to easily remove dust or stains would also be very helpful. Thanks in advance!
Dustin
12 Mar 2024 09:47
A soft microfiber cloth is best for regular cleaning. Slightly dampen it to remove dust. For stains, you can use a little dish soap in lukewarm water, but avoid harsh cleaning agents.
TRADI
12 Mar 2024 15:05
Hello nycolas,
I understand your concerns well, as HEMNES furniture has a painted surface that is sensitive to chemicals. My recommendation is to regularly wipe the furniture first with a dry dust cloth or a very lightly dampened microfiber cloth. This prevents dust from settling and avoids the need for intensive scrubbing later on. For tougher stains, mild castile soap or a neutral all-purpose cleaner suitable for wood is ideal. Be careful not to make the cloth too wet to avoid moisture damage.
Additionally, you should treat stains promptly because otherwise they can penetrate the surface. A trick I use myself is to apply a slightly damp cloth with baking soda to the affected areas, let it sit, and then wipe thoroughly. It’s gentle but effective.
If your furniture has tight storage spaces, special small dusters or electric brushes can help you reach corners more easily. Ultimately, consistent, light maintenance is the key to reducing effort during deep cleaning.
Nathanaelk
13 Mar 2024 07:58
Hello nycolas,
since you are looking for more efficient cleaning methods, I would like to give you a slightly technical overview of what to consider in order to save time and avoid damage.
HEMNES furniture has a lacquered real wood veneer. These surfaces are less resistant to aggressive cleaning agents or heavy water use.
Step-by-step approach:
- Remove dust: A dry or slightly damp microfiber cloth works best. This prevents scratches and the use of chemicals.
- Stains (for example, coffee stains or grease): Use a mild solution of lukewarm water with a drop of neutral dish soap. Lightly dampen the cloth, do not soak it.
- Avoid aggressive scrubbing, as it can damage the lacquer layer.
- For hard-to-reach areas (drawer edges, corners), use soft brushes or small dusters.
Tips to save time:
- Establish a routine: Weekly light wiping prevents stubborn dirt buildup.
- Use a spray cleaning system with microfiber cloths – this allows you to clean without many extra steps.
- For surface cleaning, I strongly advise against products containing ammonia or alcohol.
One question for you: Are there any specific types of stains that are particularly troublesome? This way, I can assist you even more precisely.
lubla
13 Mar 2024 10:41
TRADI schrieb:
For heavier dirt, mild curd soap or a neutral all-purpose cleaner suitable for wood is ideal.
I completely agree. I would just add that it is essential to wipe down with clear water afterward to avoid leaving any residue on the surface. Otherwise, the furniture will have an uneven shine.
