ᐅ Are there any tips for significantly reducing the assembly time of Pax?
Created on: 5 Jul 2020 08:34
Tufulis
Tufulis
5 Jul 2020 08:34
I have a rather technical question and hope that some of you might already have experience with this:
Are there any tips to significantly reduce the build time of Pax?
I am currently working on a project where I am setting up Pax in a relatively complex environment—many modules and typical standard processes are involved. Still, the build process feels too slow for my taste, which considerably slows down the development flow and testing, especially during repeated starts.
I am interested in concrete approaches, settings, or workarounds that have been proven to noticeably speed up the process.
It would also be important to know which factors have the most impact—such as parallel loading, cache management, or specialized optimization options in the configuration files.
Thanks in advance for your tips! I look forward to precise and effective suggestions.
Domau0
5 Jul 2020 10:57
Hello Tufulis,
regarding your question about tips to significantly reduce Pax’s build time, I can share some insights based on many years of experience.
The build process of Pax, especially with more complex configurations, is mainly influenced by several factors:
- Module initialization: The more modules loaded in parallel, the greater the potential to reduce time. However, this heavily depends on available resources (CPU cores, I/O bandwidth).
- Cache usage: Effective cache management can dramatically shorten the build process. This involves not only reusing existing cache files but also properly configuring it to avoid unnecessary overwriting or clearing.
- Lazy loading or deferred loading of components: When possible, elements that are not immediately required at startup should only be loaded when actually needed.
- Configuration optimization: It is worthwhile to review configuration files for unnecessarily complex or redundant settings. Sometimes using less universal but more precisely tailored configurations helps.
For more targeted advice, I’d need to know which version of Pax you are using, what type of system (hardware, etc.), and whether there are specific modules causing particularly long load times.
I also wonder if you have already tried parallel loading and if you are currently using profiling tools to identify bottlenecks.
If you like, I can also send you a kind of step-by-step checklist to help locate the most common build issues.
ronti
5 Jul 2020 11:23
Speeding up Pax?
- Enable parallel module initialization
- Do not clear the cache, only update it
- Set up lazy loading for optional modules
- Deactivate unnecessary modules before startup
These steps usually have the greatest impact.
Luciandi
6 Jul 2020 09:48
Domau0 schrieb:
Also, I’m wondering if you’ve already tried loading in parallel and if you’re currently using profiling tools to identify bottlenecks.
I think that’s a very good approach. I’d like to add that, for me, it was often frustrating to keep losing time during the setup process without seeing any noticeable improvement in efficiency—you quickly end up feeling stuck.
If you, Tufulis, want, I can suggest marking small intermediate steps where the system takes the most time. For example, I discovered that certain database connections were being opened unnecessarily often, which significantly delayed startup.
Sometimes it’s small things, like unoptimized queries or outdated module extensions, that add up.
So just have courage—a well-structured setup with targeted measurement often helps more than randomly changing settings.
And don’t worry about making mistakes during this—that’s part of the learning process many here are familiar with.
hauklo
7 Jul 2020 14:12
Summary from my perspective on "Are there tips to significantly reduce Pax build time?":
- Conduct a resource analysis: CPU and I/O bottlenecks often determine how fast the build can proceed.
- Enable parallel loading only if the hardware supports it effectively; otherwise, context switches may cause additional delays.
- Review caching strategies and keep the cache as persistent as possible, especially for frequently used modules and data.
- Apply lazy loading rigorously. That means loading only what is immediately necessary for operation.
- Optimize configuration: strictly avoid redundant or unnecessary code.
- Use monitoring or profiling tools that clearly show which steps take the longest. The optimal solution always depends on the specific situation.
In conclusion, I recommend assessing the willingness to possibly adjust existing packages or modules if they are slowing down the build process.
If the hardware setup or Pax version is known, I can gladly provide more specific advice.
