ᐅ Are there any tips for mounting IKEA Brimnes furniture to the wall?
Created on: 18 Nov 2016 20:13
Lauselim39
Lauselim39
18 Nov 2016 20:13
I recently purchased some IKEA Brimnes furniture and now face the challenge of securely attaching it to the wall. I’m especially interested in any specific tips or proven methods to consider when mounting this type of furniture. The construction seems relatively lightweight but not without some concerns, especially if there are children in the house.
I would like to know which types of wall anchors and screws are best suited, whether it’s essential to use a level, and if there are general recommendations regarding the height for mounting.
Has anyone had experience with Brimnes furniture and can share firsthand advice on what to watch out for to ensure the furniture is stable and safely secured?
Thanks for your tips and insights!
George
18 Nov 2016 20:46
The most important thing is to use the fastening materials provided by IKEA.
- Choose anchors and screws suitable for the wall type (e.g., cavity anchors for drywall).
- Always secure the furniture at two points.
- Use a spirit level to ensure the brackets are installed straight.
This way, you’ll be on the safe side.
fidasi
19 Nov 2016 08:37
Hello Lauselim39,
your question about the wall mounting of the IKEA Brimnes furniture is definitely valid, as the stability depends heavily on the type of fasteners used and the precise installation.
Regarding the choice of anchors:
- For solid walls (concrete, brick), metal expansion anchors or heavy-duty anchors are recommended.
- For lightweight partition walls or drywall, be sure to use special hollow wall anchors; simple plastic anchors are usually too weak here.
Procedure:
- First, identify the wall type (simply with a drill or magnet) to select the appropriate anchors.
- Also check the screws supplied by IKEA for their length and thickness, as sometimes the IKEA set alone is not sufficient.
- Make sure that the mounting points of the furniture (usually on the back panel) rest directly against the wall without any gaps.
Regarding height and positioning:
- The Brimnes series can be quite tall; I would secure the furniture at least at two points in the upper half to reduce the risk of tipping.
- If there are children in the house, I strongly recommend using wall mounts that are strong enough and cannot easily pull out.
Potential pitfalls:
- Sometimes there are cables or water pipes inside the wall, so avoid placing anchors in those areas.
- A spirit level is essential to ensure everything is installed straight.
What type of wall do you have? Should I provide more details?
neo59
20 Nov 2016 11:29
fidasi schrieb:
Procedure:
- First, determine the wall type (simply using a drill or a magnet) to select the appropriate anchors.
Just a brief note on that: I recommend not only measuring but also considering how much load the wall fixing will ultimately bear. It is by no means guaranteed that the screws and anchors supplied by IKEA will be suitable for every type of wall. There are different Brimnes models with varying weights and uses (cabinets, shelves, beds).
George schrieb:
Furniture must be secured at two points.
I think this is too general – depending on the piece of furniture and its size, you should consider more fixing points on the wall to better distribute the load and especially to significantly reduce the risk of pulling out under stress (e.g., if children tug on it).
Additionally, I would recommend checking for any electrical or plumbing lines inside the wall before installation, as already mentioned. The risks here are often underestimated.
In summary:
- Accurately identify the wall type
- Use multiple fixing points, not just two
- Take into account the load profile of the furniture
- Careful installation with suitable anchors
I believe that from a safety perspective, this is certainly not a subject for temporary solutions.
