ᐅ Are there any tips for transporting MALM furniture?
Created on: 12 Mar 2022 09:23
DUNOTI
DUNOTI
12 Mar 2022 09:23
I am planning to buy some MALM furniture from IKEA, but I have concerns about transporting the mostly large and bulky pieces. I am wondering if anyone has tips or proven methods for safe and as easy as possible transport of MALM furniture. I am particularly interested in how to protect the furniture best, what type of vehicle is ideal, and whether it is worth partially disassembling the furniture beforehand. Practical tips on how to store or secure the pieces during transport would also be very helpful.
Does anyone have practical experience or recommendations that go beyond the usual advice? Thanks in advance!
meoreo
12 Mar 2022 09:47
It is best to fully disassemble the furniture before transport and protect the individual pieces with blankets or bubble wrap.
A station wagon or small van is ideal, as the parts are usually long and heavy.
Secure everything with ratchet straps to prevent any movement during the drive.
kibutar
12 Mar 2022 13:16
Your question about transporting MALM furniture is very good and multi-faceted—thank you for asking it so precisely.
First: The MALM series often consists of large panel surfaces that, due to their construction (particleboard with foil coating), are sensitive to impacts and scratches. Therefore, it is indeed highly advisable to disassemble the furniture completely as much as possible before transport. Each part should be wrapped in several layers of bubble wrap or clean blankets, paying special attention to protecting edges—using pieces of cardboard, for example—since they can quickly get dents or chips otherwise.
Regarding the vehicle: A station wagon or a small van with a loading area of at least 1.5 meters (5 feet) in length is recommended, so the long parts can be transported lying down. When loading, make sure the panels lie flat and do not tilt, and secure all parts with straps to prevent shifting during the drive. Significant damage can occur especially when braking or taking curves if parts move around.
Also, avoid placing heavy items directly on the surfaces. When temporarily storing parts, it’s best to lay them horizontally on a flat surface, not standing upright, as this can compromise the stability of the particleboard.
One more question: Do you plan to assemble the furniture immediately at the destination or store it temporarily? This can affect the level of protection needed. For longer storage, a dry, well-ventilated environment is recommended to avoid damage from moisture or warping.
If you like, I can also provide you with a step-by-step guide for disassembling and packing the furniture.
I’m also curious: How large is your vehicle, and how much experience do you have with moving furniture?
LAURE-TA
13 Mar 2022 08:54
Regarding the topic "Are there tips for transporting MALM furniture?" I would like to add a brief structured guide that might be helpful:
1. Preparation:
- Check if you can fully disassemble the MALM furniture on-site (remove doors, back panels, drawers). This makes transportation easier and reduces the risk of damage.
2. Furniture protection:
- Wrap all parts with foam wrap, bubble wrap, or at least soft blankets.
- Additional edge protection, such as cardboard pieces, helps protect vulnerable corners and edges.
3. Loading and transport:
- Place flat, large parts on a level surface to prevent warping.
- Use tie-down straps or moving belts to secure the furniture inside the vehicle.
4. Vehicle choice:
- Ideal options are station wagons or rental vans with sufficient loading space. A car with the rear seats folded down often cannot accommodate all parts.
5. After transport:
- Reassemble as soon as possible, since stored disassembled parts may warp, especially in humid environments.
kibutar schrieb:
möchtest du die Möbel gleich am Zielort zusammenbauen oder vorübergehend lagern? Das kann Auswirkungen auf den Schutzbedarf haben.
This is an important point – depending on whether you assemble the furniture immediately or store it temporarily, you should take different measures, especially regarding humidity and storage duration.
I hope this overview provides a good foundation for transporting your MALM furniture. If you want more details on any points, just ask!
