ᐅ Do you have any tips for transporting BILLY shelves without causing damage?
Created on: 24 Mar 2023 09:37
RolfdiHello everyone,
I am planning to transport some of my BILLY shelves from IKEA soon and want to avoid any damage during the process. Are there any specific tips or proven methods on how to best secure or prepare the shelves to prevent scratches, breaks, or warping during transport? Recommendations on packaging materials or the proper order for disassembly and reassembly would also be helpful.
Thank you in advance for your advice!
to effectively prevent damage during the transport of BILLY shelves, here is a simple step-by-step guide:
1. Disassemble: Separate all components – side panels, shelves, back panels, and doors. This allows for easier packing and reduces the risk of the shelf breaking at one point.
2. Protect back panels especially: The thin hardboard back panels are very fragile. I find it best to place them between two sturdy cardboard sheets or wrap them thickly in bubble wrap.
3. Use protective coverings: Wrap all individual parts with bubble wrap. Alternatively, blankets or towels can be used as padding if you prefer not to use bubble wrap.
4. Secure in the vehicle: Make sure the parts are placed tightly together to prevent shifting. Heavier parts should be placed at the bottom, lighter ones on top, to avoid deformation.
5. Assembly tips: Before disassembling, note which screws belong to which parts. This saves confusion during reassembly.
A common mistake is transporting the shelf partially assembled — this greatly increases the risk of damage!
Hope this helps.
Hope this helps.
Nathanaelk25 Mar 2023 08:49In addition to the previous advice, I would like to explain the specific material properties and their handling in more detail to ensure the transport goes with minimal damage.
The BILLY shelves are mostly made of particleboard with a melamine coating. These surfaces are fairly resistant to scratches, but repeated careless handling can still cause visibly lasting damage.
Important points:
- Disassembly of the furniture: It is best to remove all shelves, side panels, and back panels. Pay close attention to the small dowels and screws – it would be a pity if they get lost or damaged, as this would make reassembly difficult.
- Back panel method: The thin hardboard back panels are particularly fragile. A common mistake is transporting them loosely or stuffing them between other heavy items. I use sturdy cardboard boxes, but stable plastic sheets as protective layers have also proven effective to avoid pressure marks.
- Packaging: Bubble wrap offers good protection against impact and shocks but does little to prevent scratches caused by friction. Therefore, I always place a soft cloth or furniture pads underneath the bubble wrap.
- Transport in the vehicle: The parts should ideally lie flat. I make sure the shelf components do not wobble or knock against each other. For this, I use ratchet straps to secure the parts firmly.
Finally, a question for you: Will you be moving the shelves to a different house or just within the same apartment? Are cutting tools, screwdrivers, and assembly materials available on site? This can also affect how you prepare.
Best regards and good luck!
Important points:
KUDAISY schrieb:
A common mistake is transporting the shelf half-assembledI know that all too well! I once transported my BILLY shelf partly assembled and I’m still annoyed about the scratches.
My advice: definitely spend some time disassembling it and secure each piece individually. Maybe use blankets combined with bubble wrap.
Also: label the parts so rebuilding is much more enjoyable and you don’t have to spend ages searching.
It’s amazing how much less stressful the assembly is afterwards! 🙂
Good luck with the transport, I’m sure you’ll manage it! 😉
