ᐅ Are there any tips for transporting fully assembled IKEA PLATSA units?
Created on: 28 Feb 2018 08:37
Klobu
Klobu
28 Feb 2018 08:37
I am planning to move soon and intend to transport my IKEA Platsa shelving unit fully assembled. Since it is a modular shelving system, I am wondering if anyone has practical tips or proven methods for safely and carefully moving such furniture while it remains assembled. Specifically, I am interested in whether there are special packing materials recommended, how to stabilize the shelving system to prevent damage or deformation during transport, and if it is really better to completely disassemble parts or if some components are best left assembled. Has anyone experienced how the material holds up when moved in its assembled state? I would appreciate any advice on handling, protective measures, or transportation techniques.
Johnathon
28 Feb 2018 10:09
Regarding the question of transporting an assembled IKEA PLATSA shelving unit, it should be noted that these systems are primarily designed for modular use, which generally makes disassembly easier. However, there are situations where one might want to transport it fully assembled—either due to time constraints or because disassembly seems too complicated.
The most important factor is the stability of the shelving unit. Before transport, I recommend systematically checking all connections to ensure they are secure and tightening them if necessary. The piece of furniture should then be thoroughly padded, for example with blankets or foam, to protect edges and surfaces from shocks. Straps can also help keep the shelving together, especially if individual modules are not firmly connected and might shift against each other.
Transport should ideally be done with the unit standing upright, as the shelving system is not designed to withstand lateral loads. Finally, I suggest considering removing the most fragile parts—doors, back panels, or shelves—as these are more likely to break or deform.
To give a complete assessment, it would be helpful to know the size of the PLATSA unit and details about the transport vehicle. Are there many stairs to negotiate? How long will the transport take? All these factors influence the process.
edisondan
1 Mar 2018 07:46
From a technical perspective, the following points are crucial when transporting an assembled IKEA PLATSA:
- Check and tighten all screws and connectors before transport to minimize movement.
- Protect delicate surfaces and edges with soft materials such as moving blankets, stretch wrap, or foam. These materials better absorb shocks and prevent surface damage.
- Stabilize the shelving unit with ratchet straps or tie-down straps, especially for modules connected with only a few fasteners.
- Transport the unit vertically whenever possible; transporting it lying down increases the risk of warping and damage to back panels and doors.
- Remove shelves and doors if they are easily damaged or likely to rattle.
Disassembling individual modules is often more practical for workflow and protection, as it reduces the load on each part and makes handling easier during loading and unloading. However, if you want to save time and the furniture piece is not too tall or large, you can apply the suggested protective measures using padding, straps, and cushioning materials. After the move, recheck all screws, especially on the base and corners.
Nigel
1 Mar 2018 12:22
edisondan schrieb:
Transport preferably in a vertical position; horizontal transport increases the risk of warping and damage to back panels and doors.
This is very important. Additionally, it can help to wrap the shelf with blankets and secure it with ratchet straps. If there is space in the vehicle, place it as close as possible to a solid surface to prevent slipping.
