ᐅ Are there any tips for quickly assembling the IKEA Hemnes furniture?
Created on: 19 Feb 2022 14:37
marchen3Hello everyone, I am about to assemble an IKEA Hemnes shelf but have some concerns about how long the assembly might take. Does anyone have tested tips or strategies to make assembling Hemnes furniture faster and more efficient without sacrificing stability or quality? I have already prepared quite a few tools but would also like to know if there are helpful shortcuts, sequences, or tricks for handling the included materials that could noticeably simplify the assembly. I am especially interested in advice on how to avoid common pitfalls that could be time-consuming. Looking forward to your experiences and recommendations!
A quick tip upfront: Sort all the parts by type before assembly and ideally number them as well. This saves a lot of time when searching.
Even better, go through the steps in the instructions and prepare the screws and anchors needed for each step in advance. This helps to avoid constant searching and delays.
Landontau20 Feb 2022 10:28[@marchen3, post: y1r4t4, member: XXX]
Hello! I completely understand your concern; flat-pack furniture can sometimes be tricky. Here is a short guide that can help you assemble your furniture faster and more smoothly:
- Preparation is key: Have your tools ready (Phillips screwdriver, hammer, etc.) and clear some space to lay out the parts in an organized way.
- Number the packages or parts according to the instruction manual to avoid wasting time searching.
- Follow the instructions step by step. If a step seems complicated, read it twice before starting to assemble.
- Use a rubber mallet instead of a steel hammer to protect wood surfaces and avoid rough adjustments.
- Tighten screws by hand only until the entire unit is nearly assembled, then you can fully tighten them — this prevents misalignment.
- Assemble the furniture on a carpet or a soft surface to protect the wood from scratches.
Be careful with the dowels: they must fit well; otherwise, the stability will suffer. With Hemnes, the parts are generally well cut, but still make sure no part is misaligned.
In summary: order, method, and patience are your best allies. With that, you can assemble it at a good pace without compromising quality.
Landontau schrieb:
- Follow the instructions step by step. If a step seems complicated, read it twice before starting the assembly.Exactly! I also tried assembling a Hemnes piece and was really overwhelmed at first, but with a bit of calm and focus, it got much easier!
Another tip from me: Take breaks if you notice you’re getting stressed. This helps avoid mistakes that would cost extra time later. And if you have someone to help you – even better! It’s much more enjoyable and faster when you work together!
You can do this, just keep at it and don’t rush! 😊
