ᐅ Do you have any tips for safely disassembling IKEA BESTA units when moving?
Created on: 2 Jun 2022 08:37
Arben45Hello everyone, I am preparing for an upcoming move and have several IKEA BESTÅ cabinets that I would like to disassemble and transport safely. My question for you is: Are there any special tips or tricks for taking apart the BESTÅ units to avoid any damage? I want to prevent the panels from splitting or the joints from bending or breaking during reassembly. Additionally, I’m interested in any advice on how to best organize and store screws and fittings to ensure the rebuild goes smoothly. I would appreciate any detailed instructions or recommendations on the tools needed!
Hey Arben45, great question! The BESTÅ can be a bit tricky to disassemble, but with the right approach, it’s not that bad. My advice: keep screws and fittings in small, labeled bags – that way you’ll find everything again during assembly. Also, when loosening the fasteners, avoid using force; try to gently separate the parts instead to prevent the edges from chipping. Oh, and I always use small foam or felt pads between the panels when stacking them to avoid scratches. Good luck! 😉
Hello Arben45, I understand your concern. BESTÅ furniture is designed to be fairly sturdy, but you should proceed carefully when dismantling. It is important to remove all doors and back panels first – this helps relieve tension in the frame. Then, carefully loosen the screws and dowels. For the screws, it’s a good idea to use small labeled containers to avoid mixing them up. In terms of tools, I recommend a cordless drill with a torque setting, which allows you to loosen the screws gently without stripping them. Also, make sure to transport the connectors well padded during the move to prevent damage. If you like, I can also create a step-by-step checklist for you.
Friedrich3 Jun 2022 09:47Hello Arben45, I can imagine that the idea of dismantling your beloved BESTÅ cabinets might be a bit stressful. I felt the same way because I was worried about damaging something and ending up with a pile of broken pieces. To be honest, the joints are not really designed for frequent disassembly. If you notice any stiffness or resistance when unscrewing, take a moment and try applying gentle heat, for example with a hairdryer, to help loosen the wood more easily. That really helped me a lot. Also, when packing, be careful not to stack heavy items on top of the disassembled parts. I hope this helps ease your concerns a bit!
I find it interesting, Arben45, how often disassembly is described as a tricky issue when it comes to IKEA furniture. The fact is: the BESTÅ units are modular, but they are not designed to be taken apart and reassembled regularly without wear. This means you should be careful, but not overly so. Screws often last longer than you might think if handled properly. From my point of view, it is important to carefully document the position of each screw – photos or small sketches can help avoid problems during reassembly. Also, consider how you handle the back panels: these are often fixed with small nails, which can easily split the material. Damaging them risks distortions in the cabinet structure. My suggestion: during transport, it’s better to remove and protect the back panels well rather than fixing them in a risky way. If you’re wondering whether to buy new back panels, in some cases they are a reasonable “wear item.”
