I recently noticed a minor defect on the footboard of my IKEA Malm bed. Specifically, one of the footboards is a bit loose, and the surface has some slight scratches in several spots. Since I don’t want to replace the entire part because the bed is otherwise fine, I’m wondering: Are there any tips for repairing Malm footboards?
I’m particularly interested in methods for fixing small cracks and paint damage without having to sand down or repaint the whole piece. Any advice on securing the footboards more firmly would also be helpful—I suspect that some of the screws no longer hold as well as they used to.
Has anyone had experience or proven tricks for improving stability and making repairs look good? Suggestions regarding the necessary tools, materials, and step-by-step instructions would be very much appreciated.
Thanks in advance!
Thanks in advance!
Hello Nakudeo,
Regarding your question: Malm baseboards are often made of thin particleboard with a melamine coating or foil, which can make repairs a bit tricky, especially when dealing with paint damage.
My advice: For small scratches and scuffs, wood repair wax or so-called furniture wax works very well. It can be color-matched, and the wax can be gently rubbed into cracks in small amounts. This usually makes the area look quite discreet.
If the baseboard is loose, first check whether the screws still hold firmly or if the holes are damaged. Often, applying some wood glue into the hole and then filling it with a suitable toothpick or wooden dowel works well. After that, you can screw the piece back in place—this will restore a solid hold.
If the paint damage is deeper or larger areas are affected, very fine sandpaper (e.g., grit 240) can be used, followed by a matching wood stain or repair pen. However, be careful, as melamine surfaces don’t always yield perfect results.
I hope this helps you.
blapau schrieb:
For small scratches and scuffs, wood repair wax or so-called furniture wax works very well.I completely agree.
In short: use wax or repair markers for wooden furniture. For loose fastenings, wood glue and toothpicks in the screw holes help. That’s it.
I would like to add a few tips, as I have repaired several Malm parts myself.
First of all: The reason why screws often fail to hold in Malm legs is usually because the MDF or particleboard material in those areas has become softened or torn out. As mentioned before, I recommend filling the holes with wood glue and wood shavings or toothpicks, then allowing it to dry thoroughly. This restores a stable surface.
For surface repairs: Depending on the size and depth of the damage, acrylic wood filler can sometimes be a good solution. It’s easy to shape in small amounts and can be finely sanded once dry. Afterwards, you can color-match the repair using touch-up markers or furniture repair kits.
It is especially important to work carefully on painted or coated surfaces and to test on inconspicuous areas first.
If you’re not very experienced with DIY, it’s best to avoid heavy sanding because the thin melamine layer can quickly become damaged.
I hope this helps! If you like, I can also provide a simple step-by-step guide.
