Hello everyone, I have an issue with my Ikea Hemnes drawers, where the sliding rails no longer seem to work properly. Specifically, the drawers are hard to open, sometimes get stuck, and in some cases won’t slide out smoothly. I suspect that either the metal rails are damaged or the plastic rollers are worn out, but I’m not entirely sure. Does anyone have experience or tips on how to best repair or restore these drawers without having to buy complete replacement parts? I’m mainly looking for advice on troubleshooting, but also any suggestions for affordable tools or tricks to improve the sliding performance. Thanks in advance!
Hello lefozar,
regarding your issue with the HEMNES drawers, I can provide a simple guide that many have successfully used.
- First, you should remove the drawer completely; to do this, usually unlock the small levers at the end of the metal runners.
- Check the running rails and rollers for damage: cracks, bent metal parts, or broken plastic components are the most common issues.
- Sometimes dirt and dust are the cause of stiffness. In this case, cleaning the runners and rollers with a lint-free cloth and isopropanol helps.
- Another important point is lubrication: use a silicone-based spray or a special lubricant for plastic and metal gliders. I wouldn’t recommend WD-40, as it often hardens and attracts more dirt.
- If the plastic rollers are worn or broken, they can usually be replaced individually. Replacement rollers for the HEMNES series can be found on eBay or directly from Ikea.
- For bent metal runners, careful realignment with pliers can help, but be cautious not to cause damage.
Summary:
1. Remove the drawer
2. Clean
3. Lubricate
4. Replace defective parts
If you proceed step by step, you can usually improve the drawers significantly. Good luck!
Summary:
2. Clean
3. Lubricate
naujon schrieb:
If the plastic rollers are worn or broken, they can usually be replaced individually. Replacement rollers for the HEMNES series are available on eBay or directly from Ikea. That is correct and should be the first step after simple cleaning and lubrication do not improve the situation. The rollers are specifically designed to handle the loads of HEMNES drawers, and replacement parts are compatible.
Additionally, I recommend checking the drawer slides for proper alignment when removing the drawer. Sometimes the guides shift due to incorrect insertion or subsequent damage from stress, which can cause jamming.
A small tip for troubleshooting: check the rolling direction of the rollers, as they can get stuck if twisted incorrectly in the drawer slide groove.
Finally, note that with older series, the wood of the drawer front can sometimes swell slightly, which also affects how smoothly the drawer pulls out. In this case, sanding the contact area can help.
Hello lefozar,
I would like to add that with the HEMNES series, it is important not to exceed the weight limit of the drawers. Heavy items put excessive strain on the rollers and slides, which leads to premature wear.
Additionally, you can check the following points:
- Are the screws holding the runners still tight enough? Loose screws cause misalignment.
- Check the attachment points of the drawer itself; sometimes small pieces of wood or screws become loose there.
If everything is technically sound, using fine sandpaper (grit 240 to 320) to carefully smooth the edges inside the drawer can help reduce any new friction.
I hope these tips help you further.
