ᐅ Are there any tips for repairing Ikea Hemnes cabinets?
Created on: 14 Sep 2020 08:17
tiFernando
I have several Hemnes cabinets from Ikea at home that, over time, have started to loosen in various places or show minor damage such as torn joints and some drawers that stick. I’m specifically interested in practical and proven tips or guides for repairing Hemnes cabinets.
What would be especially helpful are suggestions on tightening screws, replacing or reinforcing connectors, and dealing with damaged wooden parts. Experiences with special tools or replacement parts would also be appreciated.
I would be grateful if those who have already done repairs on Hemnes furniture could share their knowledge – ideally including advice on how to avoid mistakes and keep the furniture stable for as long as possible. Thanks in advance!
mifra
14 Sep 2020 10:44
Regarding the issue of moisture and the resulting damage to wooden furniture, especially pine, it is advisable to consider the following preventive measures:
- Optimize indoor climate: maintaining a consistent humidity level around 45-60% helps keep the wood stable.
- Regularly air out furniture and, if possible, avoid direct contact with cold or damp exterior walls.
- Use a breathable wood protection to preserve the material’s ability to breathe.
With regard to your desire to preserve the appearance, I recommend avoiding solvent-based varnishes or waxes that may seal the surface. Instead, moisture-repellent wax emulsions or water-based wood oils are suitable, which can be easily applied and gently dabbed on.
These protect from within without affecting the natural grain or matte finish.
Mekau
14 Sep 2020 11:02
Wood glue is your best friend for small cracks or worn screw holes.
If the screw no longer holds, simply apply wood glue into the hole and add a few small wood pieces. After it dries, you can screw the screw back in—it usually holds well.
Katau
14 Sep 2020 11:28
I would like to add that when tightening screws, it is important not to fully loosen them while the cabinet is still standing, as the furniture may become unstable and could potentially warp.
Tighten gradually and only as much as needed to create slight tension. If a more thorough repair is required, disassemble the cabinet first; this also allows better control over the joints.
Additionally, I have had positive experiences using wooden dowels, which can be custom-made or purchased beforehand. These improve stability when they are accurately sized and used together with glue.
lorena
14 Sep 2020 12:01
tiFernando schrieb:
Are there additional measures to protect wooden parts from moisture without significantly altering the surface?
Yes, especially regarding moisture: Besides the measures mentioned by mifra, a small dehumidifier can also be helpful, particularly in poorly ventilated rooms.
Additionally, you should
- avoid water pooling,
- reduce contact between the cabinet base and cold or damp floors (felt pads or small adjustable feet can help),
- and ensure that the furniture is not placed directly behind radiators, as strong temperature fluctuations can put extra stress on the wood in certain areas.
These tips have a truly positive effect on the furniture’s durability without affecting its appearance.
nubar
14 Sep 2020 12:35
One point that has been somewhat overlooked in the discussion is the use of original replacement parts from Ikea.
If screws or other fasteners are damaged or lost, I recommend using the original parts directly, as they are specifically designed for the structures of the Hemnes cabinet.
However, it can sometimes be more cost-effective to use high-quality alternative parts if the originals are no longer available, provided the dimensions match and the material quality is appropriate.
I also advise keeping clear documentation during longer repairs to be able to respond more quickly in case of any subsequent damage.
faso31
15 Sep 2020 13:04
tiFernando schrieb:
@faso31: You are right, the environment for our Hemnes cabinets is not ideal, as it is somewhat damp and the cabinets are placed close to an exterior wall, which can become cold and damp at times.
In this case, my recommendation would be to consider the following long-term strategy:
- Improve the insulation of the exterior wall, for example through added thermal insulation or wall coatings.
- Avoid placing furniture directly against the cold wall; leave a small gap to allow better air circulation.
- Use air circulators or small fans to maintain continuous airflow.
Without these accompanying measures, the furniture in such an environment will be much more vulnerable to damage from moisture and temperature fluctuations.
