ᐅ Are there any tips for protecting my Ikea PLATSA furniture with daily use?
Created on: 16 Aug 2023 09:18
altan69Hello everyone,
I own some Ikea Platsa furniture that I use daily—mainly cabinets and shelves that are frequently opened, moved, and used. Since these pieces are functional but positioned in the mid-price range, I want to maintain them as long as possible without them wearing out or getting damaged from everyday use.
My question is: Are there any proven tips or tricks to effectively protect my PLATSA furniture during daily use? I am especially interested in whether there are specific care products, protective films, or assembly recommendations that can help prevent material wear, scratches, or instability. I look forward to hearing about your experiences or suggestions on these points—also ideas on how to detect typical wear problems early and prevent them.
altan69 schrieb:
Are there any proven tips or tricks to effectively protect my PLATSA furniture from daily use?Hi! The PLATSA series is cleverly designed to be flexible. For everyday use, a bit of routine care and attention often goes a long way 😊.
- Regularly apply a light oil to hinges and moving parts to keep them smooth and prevent squeaking or stiffness.
- Attach soft felt pads under the feet to protect both the furniture and the floor when moving it.
- Instead of materials that scratch easily, use coasters or mats made of softer fabric, especially when placing heavy or sharp-edged items on it.
If scratches do happen, don’t worry – you can often cover them up with a wax repair stick in a matching color or a velvet polish.
Sometimes a little extra care goes much further than you’d expect. Good luck – and don’t worry, PLATSA can take quite a bit 😉
altan69 schrieb:
Are there any proven tips or tricks to effectively protect my PLATSA furniture during daily use?The PLATSA series is primarily made of particleboard with a melamine coating. To reduce wear, I recommend the following measures:
- Avoid direct moisture on the surface, as this can cause swelling over time.
- Use felt or rubber pads under the feet to prevent abrasion and scratches on the floor.
- Assemble the furniture according to the IKEA instructions and check the screws regularly to ensure stability.
- For cleaning, use a damp, well-wrung cloth and avoid harsh cleaning products, as they can damage the surface.
- Optionally, you can apply protective films to the shelves to prevent scratches.
Detecting loose connections and minor damages early allows for timely repairs, which can extend the furniture’s lifespan.
In addition to the points already mentioned, I would like to provide a brief guide for protecting and maintaining PLATSA furniture, which is especially useful with daily use:
1. Check stability: Inspect all screw connections at least every 3-4 months, as they can loosen with use. Regular readjustment prevents wobbly or unstable furniture.
2. Maintain hinges and sliding rails: Use a silicone-based lubricant. It prevents squeaking and keeps movement smooth without damaging the plastic. Important: Do not use oil on felt or wood, as it causes stickiness.
3. Protect surfaces: When placing heavy or sharp-edged objects, transparent protective films or soft pads are recommended. This helps avoid scratches and pressure marks.
4. Proper cleaning: Avoid standing water and harsh cleaners that can damage the melamine coating. Use lukewarm water with a mild dish soap and dry the surface promptly.
5. Caution with assembly instructions: Strictly following the Ikea assembly guidelines is essential, as improper assembly can lead to faster wear and instability.
Summary: Regular checks, careful cleaning, and surface protection are key to keeping PLATSA furniture durable and safe for everyday use.
