ᐅ Are there any tips for modifying Ikea Hemnes dressers?
Created on: 4 Oct 2021 08:37
mayk_me39
mayk_me39
4 Oct 2021 08:37
Hello everyone, I am currently planning to modify my Ikea Hemnes dressers and wanted to ask if anyone has tips or proven methods, especially regarding stability and aesthetics.
I want to keep the basic frame but change some elements, for example, replacing the fronts, possibly installing drawer dividers, and maybe upgrading the handles and surface finish. It is important to me that the dresser not only looks good afterward but is also stable enough for daily use.
Does anyone have experience with this and can offer advice on material selection, suitable tools, or potential pitfalls? I would really appreciate if you could share your recommendations!
RICCARDO
4 Oct 2021 09:05
I would always start by completely removing the front panels and checking if the screws and fasteners are still secure. This way, you can install the new parts more easily and avoid unsightly damage. Important: Use good quality wood adhesive tape if you are gluing anything.
Ramon4
4 Oct 2021 09:28
Hello! To increase stability, make sure not to neglect the back panel – it often provides significant support, and if you remove it, you will need to reinforce the structure elsewhere.
Regarding the surface, sanding and repainting is a good alternative to foil or laminate, as this keeps the surface breathable and less prone to scratches.
You can easily make drawer dividers yourself using wooden strips, which you glue and screw inside – this keeps everything firmly in place.
Julien
4 Oct 2021 10:14
As an addition: If you modify the drawers, make sure the slides and rollers are in good condition. Many issues during remodeling arise when the hardware doesn’t fit properly or is too stiff.
The attachment of the handles is also crucial, as it significantly affects the appearance. I recommend using a template beforehand to ensure all holes are neat and aligned.
mayk_me39
4 Oct 2021 11:02
RICCARDO schrieb:
I would always start by completely removing the fronts and checking whether the screws and fasteners are still secure.
Thank you, that sounds like a good idea. I am considering replacing the fronts and using MDF panels, which I would then paint. Will that bond well with the existing carcass? Is there anything special I should keep in mind?
fikeo
4 Oct 2021 11:45
This works well if you attach MDF with appropriate screws and especially make sure not to use screws that are too long to avoid breakthrough.
Wood glue can also help, particularly when used in addition to screws. It is important to pre-drill everything carefully to prevent the MDF from splitting. When painting, it is best to use a primer first, as this leads to the cleanest finish.
