ᐅ Are there any tips for easy installation of IKEA Platsa units without prior experience?
Created on: 5 May 2024 08:23
Pabent
Good morning everyone! I’m planning to get the IKEA Platsa system to better organize my living room storage. Since I have little experience assembling furniture of this type, I would like to know: Are there any tips or tricks for easy assembly of IKEA Platsa that are suitable for complete beginners? I’m especially interested in advice on how to structure the assembly process, which tools might be useful, and how to avoid common mistakes. Are there practical techniques that make the assembly noticeably easier without requiring prior handyman skills? Thanks in advance for your support!
Dilen
6 May 2024 09:32
Hello Pabent, I want to go into a bit more detail because I have just assembled a Platsa combination myself and documented it quite thoroughly.
First: The Platsa series is modular, which means you aren’t really building anything from scratch but rather connecting prefabricated modules. This requires some precision and a good sequence.
- Preparation: Every single wooden beam, side panel, and back panel sometimes requires special tools, but a good, continuously adjustable cordless screwdriver is essential. It allows you to drive screws precisely without damaging the material.
- Step-by-step: Start with the side panels, preferably laying them flat on the floor, and connect the base plates before standing the carcass upright. This sequence saves you from heavy lifting and alignment work later.
- Installing the back panel: This is often the critical point. The back panel is key for stability. Make sure it is perfectly straight; otherwise, the cabinets will lean after assembly. Use a spirit level — this is standard practice.
- Dowels and screws: Sometimes the holes don’t line up perfectly. Light filing can help but be careful.
If you like, you can describe more precisely which modules you have or the dimensions of your available space, and then I could give you more specific advice.
Pabent
6 May 2024 11:18
Dilen schrieb:
If you like, you can describe in more detail which modules you have or the dimensions of your space, and I could give you more specific advice.
Thank you for the offer! I plan to place two Platsa modules, each about 60x40x89 cm (24x16x35 inches), side by side, partly with drawers and partly with doors. The room is just under 2.5 meters (8 feet) wide, and the space needs to be arranged around a radiator, which is why the flexibility of Platsa is especially interesting to me. What issues could be particularly troublesome with an uneven back panel or the radiator? How can I best ensure stability?
loken
6 May 2024 13:52
Pabent schrieb:
What problems can be especially annoying with an uneven back panel or radiator?
That’s a great question! The biggest issue is that if the back panel is not installed precisely, even small misalignments can later affect stability – drawers or doors may no longer close properly.
My advice: use wooden shims or small spacers to secure the furniture firmly against the wall. For areas around the radiator, carefully measure the modules and, if necessary, adjust or partially omit the back panel where possible.
Pabent schrieb:
How can I ensure the best possible stability?
Pay attention to installing wall brackets – these are especially important for multi-module systems. They secure your furniture firmly, even on uneven walls. One more thing: always check with a spirit level before tightening everything permanently.
Paunon
7 May 2024 08:04
A small additional tip: If you have the instructions as a PDF, you can keep them on a tablet and check off each step as you go. This way, you won’t lose track of anything. Only tighten the screws by hand at first, then align everything before fully tightening them at the end. This prevents having to disassemble everything later.
