ᐅ Do you have any tips for assembling the Ikea PLATSA system by yourself?
Created on: 20 Jan 2022 08:47
Aldoju43Hello everyone,
I’m planning to assemble an Ikea PLATSA system on my own, but I have mixed experiences with furniture assembly, especially when it comes to larger modular systems. I’m particularly interested in whether anyone has tips for efficiently and smoothly assembling the PLATSA wardrobe series alone—especially regarding handling the larger parts, maintaining stability during assembly, and organizing the individual components. Are there any proven methods or tools that make this process easier? I would really appreciate any advice on tools, steps to follow, or tricks for working with the instructions. Thanks!
Assembling the Ikea PLATSA system on your own is definitely doable, provided you plan enough space and time in advance. Here are some structured tips:
- Preparation: Unpack all parts, sort them, and check them against the instructions.
- Tools: A cordless drill with adjustable torque makes the work significantly easier.
- Key tip: Use wall brackets or aids like clamps during assembly to secure the modules against tipping over.
- Assemble in stages: Build the individual components (frames, drawers) separately and only connect them later.
- Follow the instructions carefully, step by step, and avoid connecting parts too early.
The main challenge is usually handling the large modules; it helps to assemble the module horizontally on the floor and only stand it up once it is fully secured.
Hello Aldoju43,
I’m happy to answer your question about assembling the PLATSA. I recently put together a dresser from it myself and would like to share a brief tutorial:
1. "Create a workspace" – Make sure you have enough space, ideally on a carpet or soft surface to avoid scratches.
2. "Organize the parts" – Lay out all screws sorted by type and size. A small container helps to keep everything from getting lost.
3. "Build the frame" – Start by assembling the side and back panels. Use only half of the screws at first so you can adjust it later.
4. "Use tools and help" – Having a second person is of course helpful, but if not available, you can secure the side panels with sturdy clamps.
5. "Assemble drawers and doors separately" – Build these separately before attaching them to the main cabinet.
6. "Final assembly and securing" – It’s easier to stand the cabinet upright once all screws are tightened and the frame is stable.
Common mistake: Tightening screws too much before everything is aligned. This can cause the material to warp. If you proceed carefully, assembling it solo works well.
Hey Aldoju43, I read your post and can definitely recommend the solo project with PLATSA – but yes, it does have some challenges! 😄 My motto: "Lay out and sort absolutely everything before starting assembly." This saves you from searching around wildly later on.
Also, if you’re lifting the large piece by yourself, be sure to work slowly and take plenty of breaks. These things are really bulky, and a wrong move can happen quickly.
My bonus tips:
- A wooden block or some smaller books can help raise the individual modules, for example during screwing or adjusting.
- Put on a playlist and take your time; it’s not a race.
I agree, clamps are worth their weight in gold – sometimes you feel like a manager who needs several extra hands!
My bonus tips:
Jensson schrieb:
Having a second person is obviously helpful, but if not, the side can also be fixed with a few sturdy clamps.
I just wanted to say that I recently tried assembling a similar Ikea modular system on my own, and at first, I found it quite overwhelming. Especially when you're working alone, it can be a bit discouraging.
What helped me was allowing myself breaks and not being too hard on myself. I also kept rereading the assembly instructions and visualized how the individual parts fit together before starting the actual assembly. This way, I always had a clear picture in my mind and grew more confident handling the components.
If you notice it’s getting too stressful, don’t worry—ask for some help or take a day off from it. After all, you’re not building a cathedral; it’s just furniture—it should be enjoyable!
