ᐅ Are there any tips for assembling the IKEA Hemnes for beginners?
Created on: 16 Oct 2019 18:37
knudbe
knudbe
16 Oct 2019 18:37
I am planning to assemble an IKEA Hemnes furniture piece soon, as I recently bought one and am still quite inexperienced with furniture assembly. Are there any specific tips or tricks for beginners that are especially useful for the Hemnes series? I ask because I have read that while some IKEA furniture is relatively straightforward to assemble, the Hemnes range requires a bit more precision and care. Which tools should definitely be on hand, what is the best approach to avoid mistakes and damage, and are there any common pitfalls that newcomers should be aware of? I look forward to your experiences and advice!
V
Victor54
16 Oct 2019 19:03
The question is definitely valid because the Hemnes style often consists of solid wood, which means assembly is not always as straightforward as with some MDF furniture.
knudbe schrieb:
I’m asking because I’ve read that some IKEA furniture is relatively simple to assemble, but Hemnes requires a bit more precision and care.
That is correct. For beginners, it is important to read the entire instruction manual before starting to understand the overall process. Then I would recommend sorting all screws and components first and making sure not to overlook any, as Hemnes often uses small, specific wooden dowels and connectors that can easily be confused.
A cordless screwdriver with adjustable torque is essential. Too much force can damage the wood, while too little results in loose connections. It is also important to pay attention to the assembly sequence: for example, assembling everything loosely first and then tightening it fully later helps avoid misaligned angles or warped parts.
Does anyone have specific experience with unexpected challenges when assembling Hemnes furniture?
Nils58
17 Oct 2019 07:22
Great question! I recently assembled my first Hemnes wardrobe myself – and it was easier than I expected! ☺️ The key is to take your time and stay calm without rushing.
Here are my tips for beginners:
- Be patient and follow the instructions step by step
- Lay out all the parts on a large, clean surface
- Keep screws and dowels separate
- Have a good Phillips screwdriver (or a cordless drill with the right bit) ready
- Ask friends or family for help, especially when assembling the larger parts – it saves a lot of stress!
Victor54 schrieb:
A cordless drill with adjustable torque is also a must.
Absolutely right! My cordless drill was worth its weight in gold. Plus, assembling the furniture is really fun once you’re in the right mood. Good luck!
taotis53
17 Oct 2019 11:16
In my opinion, there are several practical tips that can be helpful when assembling IKEA Hemnes furniture:
- Preparation:
- Prepare the work surface well (soft and large enough to prevent scratches)
- Sort all parts and tools beforehand
- Tools:
- Cordless drill with adjustable torque setting
- Rubber mallet for dowels
- Possibly a spirit level or combination square to check alignment
- Assembly:
- Read through the instructions completely at least once to understand the process
- Start by loosely screwing in the screws to allow for later adjustments
- When joining the side panels, ensure right angles (e.g. using a spirit level or carpenter’s square)
- Specifics for Hemnes:
- Due to the solid wood, be especially careful not to overtighten the screws
- Slightly moisten wooden dowels beforehand to improve fit
These recommendations are based on multiple reliable practical experiences and should especially help beginners avoid mistakes.
nanidra
18 Oct 2019 09:55
It’s interesting how much effort some people put into assembling Hemnes. Is it really necessary to spend that much time on tips for ‘just’ an Ikea shelf?
taotis53 schrieb:
When joining the side panels, make sure they are square (e.g., using a spirit level or a set square)
In my opinion, this is quite overestimated. It’s enough to follow the instructions step by step – beyond that, many things are overemphasized. If someone is really concerned about a piece of furniture like this, they might be better off choosing prefabricated solutions or hiring a carpenter right away.
Victor54 schrieb:
Then I would recommend sorting all screws and components first and not overlooking any
That’s a reasonable idea, but I think it’s mostly necessary for more complex furniture. Hemnes is quite straightforward and easily manageable with a bit of focus.
