ᐅ Are there any tips for assembling IKEA Brimnes furniture without prior experience?
Created on: 26 Mar 2021 08:17
sean61Good morning everyone, I am about to assemble an IKEA Brimnes bedroom furniture set but have no experience with furniture assembly or flat-pack construction. Are there any useful tips or recommended approaches here in the forum, especially for Brimnes models, that could make the assembly easier? I would appreciate practical advice, particularly regarding potential pitfalls or essential tools to have on hand. Thanks in advance!
Hello sean61, the Brimnes is largely modular in its design and requires a certain level of care regarding the assembly order. My advice is to read through the included instructions completely first to get a sense of the procedures. It is also recommended to:
- Prepare a sufficiently large, clean workspace
- Check all individual parts and fittings for completeness before starting assembly
- Have a Phillips screwdriver (PH2) and a rubber mallet ready
- It is worth loosely tightening each screw first and only fully tightening them after fitting the parts together
This approach helps avoid mistakes and unwanted warping of the components.
Hello sean61, it is completely normal to feel a bit uncertain without prior experience.
Brimnes furniture is usually well designed, and the instructions are clear. It’s important to take your time and complete each stage calmly before moving on to the next step. Often, it helps to avoid fully tightening the screws the first time, so you can easily adjust if pieces don’t fit perfectly.
Another tip: use good, bright lighting and organize screws and dowels in small bowls or bags to avoid losing anything. Don’t worry, you can manage this even without prior experience!
Hi sean61, I can understand that it can be challenging if you have never assembled furniture before. I clearly remember being nervous during my first IKEA project. The important thing is not to get discouraged if something goes wrong.
That is absolutely true, and if you follow the instructions step by step, you will manage it. Feel free to take breaks if you feel frustrated; that really helps.
Good luck, you can do it!
Josan schrieb:
The Brimnes furniture is usually well designed and the instructions are clear.
Good morning, I would like to explain the assembly process of the Brimnes series in more detail, especially for someone without experience.
First of all: The connection methods used in Brimnes mainly involve wooden connectors, cam locks, and dowels. It is important to place these precisely to ensure stability. Before you start, please keep the following in mind:
- Lay out all the parts with the labeling facing up; each panel is marked with letters or numbers.
- Use only the correct screwdriver for the screws to avoid damaging the screw heads.
- When inserting the dowels, make sure they are seated deep enough and not misaligned, which will prevent problems later.
- When assembling the side panels, it is often helpful to hold them together with someone else to prevent warping.
I wonder, are you assembling it alone or do you have someone to assist you? Especially with the larger modules, having help can make the work much easier.
Thanks for the helpful advice so far!
At this point, I plan to assemble the structure on my own, as I don’t have direct assistance available. This brings me to a question: Are there any particularly critical assembly steps or components with Brimnes that tend to be especially challenging for individuals working alone? I want to plan my time better and possibly acquire tools or aids in advance.
Laukau5 schrieb:
I’m wondering, are you assembling the structure by yourself or do you have someone helping you? Especially with the larger modules, that can make the work a lot easier.
