ᐅ Are there any tips for assembling IKEA BESTA without the instruction manual?
Created on: 21 Jul 2022 09:47
PhocasHello everyone, I am facing the challenge of assembling an IKEA Besta wall unit without the original assembly instructions. Does anyone have tips or strategies on the best way to proceed when no manual is available? I am especially interested in advice regarding the fasteners, the correct order of the parts, and how to avoid common mistakes. I have already tried to deduce the process based on the components, but I find it difficult since some parts look very similar. Is there perhaps a systematic approach or any experience with assembling this without instructions? Thanks in advance!
It’s best to first sort all the parts by type and function. Then you can start with the side walls and assemble the central frame. Common mistakes include incorrectly inserted dowels, as the guides often don’t align properly. Check carefully if the holes match; this helps with proper alignment.
mabla schrieb:
The best way is to first sort all parts by type and function. That’s already a great starting point. I also recommend assembling in a spacious area where you can lay everything out clearly – a wall unit is not a small piece of furniture.
It’s important to stay patient and not rush – especially without instructions, it’s easy to mix things up. I once changed the assembly order a bit and later had to take the whole thing apart again because I installed a part the wrong way around. 😅
Maybe you can also look at photos of similar models to get a feel for the assembly without needing a manual. Sometimes small details like metal guides or pre-drilled holes reveal where parts fit together.
Phocas schrieb:
Does anyone have tips or strategies on how to proceed best when no instructions are available?A systematic approach is crucial. Here are some precise tips:
- Group parts by function and type (side panels, back panels, shelves, connectors).
- Check the exact positions of the drill holes. This helps you better understand the order and orientation of the parts.
- Assemble the main frame first (side walls and top/bottom crossbars) before adding shelves or smaller components.
- Use the connectors as a guide: for example, special screws or metal fittings often indicate which parts go together.
- Make sure to tighten connections securely but avoid overtightening, as this can make the furniture unstable.
Finally: If possible, watching a short video with a similar BESTA assembly guide often helps to visualize the steps—even without instructions for your exact model.
