ᐅ Are there any specific tips for cleaning Ikea HEMNES surfaces?
Created on: 2 Feb 2019 09:17
pe_eymen
pe_eymen
2 Feb 2019 09:17
Are there any specific tips for cleaning Ikea Hemnes surfaces? I own several pieces from the HEMNES series, mainly cabinets and dressers made of solid pine wood with a white lacquer finish. I have noticed that everyday use causes stains and small scratches to appear on the surfaces. My usual household cleaning products sometimes seem either too harsh or don’t achieve the desired effect without damaging the finish. Therefore, I’m interested in hearing if anyone has experience with gentle yet effective cleaning and care methods specifically for the lacquered HEMNES surfaces, or if there are official recommendations from Ikea beyond regular dusting. Maybe there are also proven home remedies that can be used without roughening or discoloring the surface? I look forward to practical tips or advice! Thanks in advance.
BeAndrea
2 Feb 2019 12:35
Hello, regarding your question about specific tips for cleaning Ikea HEMNES surfaces: basically, the HEMNES series is made of solid pine wood, usually painted white. This makes the surface durable but also sensitive to harsh or aggressive cleaners.
As a general rule, I recommend the following:
- Use lukewarm water mixed with mild soap or a pH-neutral cleaner.
- Avoid abrasive cleaners or strongly alkaline products, as these can damage the paint finish.
- Use a soft, lint-free cloth (such as microfiber) for gentle cleaning.
- For stains, lightly soaking with a damp cloth is often better than scrubbing hard.
- After cleaning, always dry the surface thoroughly with a dry cloth to prevent watermarks.
Ikea itself usually states on its product websites that no aggressive chemical cleaners or abrasive sponges should be used, especially on painted furniture surfaces like the HEMNES line.
Personally, I would also avoid home remedies like vinegar or citric acid directly applied, as these can dull or damage the finish. For small scratches, you can try special touch-up pens from furniture stores that match the color well.
With these tips, you should be able to maintain your HEMNES furniture well without damaging the surfaces. If you have specific types of stains, I’m happy to provide more detailed advice.
Nauman5
3 Feb 2019 10:02
- Avoid abrasive cleaners or strongly alkaline products, as they can damage the finish.
- Use a soft, lint-free cloth (for example, microfiber) to clean gently.
I fully agree – it’s not quite that strict for me, I managed with a microfiber cloth and a spray glass cleaner without damaging the white lacquered surface. Who would have thought that such a "simple" product could enhance a piece of furniture?
A small tip from me: simply don’t use too much liquid, as the wood tends to absorb it too much, and the finish might react. By the way, I always keep some furniture polishing oil on hand – applying a thin layer once a month keeps the surface looking fresh without feeling greasy.
I’m not a professional, but if you treat your furniture like a good friend, it will reward you with a great appearance – even with HEMNES! 😉
LuMarcel43
4 Feb 2019 17:46
Interesting contributions so far, especially the advice on avoiding harsh cleaners and the practical experience with glass cleaner.
However, I would like to make a case for a careful approach to lacquered surfaces. Just because IKEA advises against using aggressive products doesn’t mean that home remedies or various items sold as “furniture care” are automatically safe, as many contain aggressive solvents.
In general, I recommend:
- Carefully reading the safety data sheet of a product before use, if available.
- Testing it on an inconspicuous area to check for color changes or loss of gloss.
- Avoiding products containing alcohol, acetone, or ammonia, as these can damage the lacquer.
Also, small scratches can be smoothed out with very fine sandpaper (extremely fine), but this requires experience and caution. Careless handling can cause even more damage to the surface.
My suggestion: sustainability and consistency in cleaning are often underestimated. Regular, gentle wiping is more important than occasional “intensive” cleaning that might bring unexpected issues.
It’s also important to keep in mind that HEMNES furniture is basically affordable, mass-produced furniture, and its lacquer cannot compete with specialized designer pieces. Therefore, one should not expect too much in terms of the long-term quality of the surface.
