ᐅ Are there any specific tips for adapting IKEA Metod kitchen units to uneven floors?
Created on: 28 Dec 2020 09:23
Frederic41F
Frederic4128 Dec 2020 09:23Hello everyone,
I am currently working on installing IKEA Metod kitchens and am facing the problem that my floor is completely uneven. Despite carefully measuring the height of the uneven spots, this makes it very difficult to align the base cabinets precisely.
Therefore, my question is: Are there any specific tips or proven methods for IKEA Metod to adapt the cabinet boxes or legs to uneven floors? I am thinking of special adjustable feet, shims, or maybe technical adjustments recommended either by IKEA itself or the community.
I want to avoid having issues later with doors or the countertop due to a tilted kitchen unit. I appreciate any practical advice or references to official solutions!
The question is quite valid, since IKEA Metod is designed to be modular, but that doesn’t automatically mean all details are optimally solved for uneven floors.
Regarding adjustment to uneven floors:
- IKEA does offer adjustable feet, but with a limited adjustment range (~4 cm (1.6 inches)).
- For larger unevenness, this often isn’t sufficient.
In such cases, additional shims or wedges are often used to precisely level the furniture. However, it would be necessary to check whether stability is compromised or if stress occurs in certain areas.
Another option that, in my opinion, should be clearly discussed here is: How well do alternative systems work, such as height-adjustable frames or special plinths, which IKEA does not offer as standard?
I would like to hear about practical experiences others have had. Theoretical considerations alone are not enough for me.
Karsten4528 Dec 2020 13:12ODINFLO schrieb:
IKEA actually offers adjustable feet, but with a limited adjustment range of about 4 cm (1.5 inches).That's right, this exact range is the issue with most floors. If more than 4 cm (1.5 inches) are needed, the feet almost seem too short, which quickly raises concerns about stability.
- My experience with Metod is that you need to cleverly use wooden or plastic shims to "smooth out small unevenness" effectively.
- It's best to adjust the feet to the entrance height first, then use shims to ensure everything stays perfectly level.
And hey, it’s not brain surgery— I actually enjoy a bit of DIY! 😉 So don’t be discouraged, just grab your tools and patiently get to work.
What surprises me is that IKEA provides few official tips on this; I expected a more polished approach.
Hello Frederic41,
your question is very important because uneven floors are often underestimated and can later cause vertical alignment issues.
Regarding the tips:
- The adjustable feet from IKEA are a basic solution but not always sufficient.
- I have often had good experiences with homemade shims made from laminated wood or thick wallpaper, which you place under the feet and then adjust the threaded rods to the correct level.
- It is important to align the base cabinets precisely before connecting them to avoid stresses that could damage the kitchen fronts.
Alternatively, there are also systems with height-adjustable frames or additional plinths, but these are not specific to IKEA and are rather a generic solution.
Important: Always check that the feet still hold securely after adjusting – especially with significant floor unevenness, it’s worth testing the right combination of feet and shims before everything is screwed together.
If you want, I can also provide you with the exact measurements of the feet and the main adjustment range.
Regarding the tips:
V
vincent4629 Dec 2020 08:32Frederic41 schrieb:
Are there any specific tips or proven methods for adjusting IKEA Metod carcasses or legs on uneven floors?This topic really hits home for me. I was quite worried about how to deal with my poorly laid old building floor. What helped me was not just adjusting the legs, but patiently working with so-called "tool-free wedges" made of plastic. They can be perfectly customized and later readjusted if needed.
My experience: Use the original legs first, but don’t expect them to fix everything. Consider adding some flexibility so the cabinets don’t wobble. This is especially important when installing countertops.
Vincent46, you might also consider lightly leveling the floor — sometimes this saves a lot of time and trouble. It’s extra work but pays off in the long run.
How have others here handled this?
vincent46 schrieb:
This topic really hits home for me. I also had serious concerns about how to deal with my poorly installed floor in an old building.Your experiences are valuable because you address combined solutions.
I would like to add the following:
- Unfortunately, IKEA Metod has no official recommendation for floor leveling.
- Metal shims or rubber pads are also not official IKEA parts but can be used as flexible solutions.
It is important that the construction does not become unstable due to too many aids. You need to weigh this carefully, as the modular system clearly has limitations on uneven floors.
I keep wondering whether IKEA should seriously consider more robust adjustment options for future versions.
What are your thoughts?
