ᐅ Are there any specific tool recommendations for assembling the IKEA BRIMNES?
Created on: 2 May 2018 10:07
molipra
I am planning to assemble the IKEA Brimnes wardrobe soon and was wondering if there are any special tools or equipment that could make the assembly significantly easier or faster. I have read that some IKEA furniture comes with Allen keys, but these are not always ideal, especially if you want to build the wardrobe more robustly and securely.
Are there any specific tool recommendations you have for assembling the BRIMNES wardrobe—such as particular screwdrivers or tips on additional aids that should be acquired? I would appreciate it if you could share your experiences or suggestions, as I want to complete the assembly as efficiently and error-free as possible. Thanks in advance!
neo59 schrieb:
Is it possible that these tool recommendations are more comfort suggestions for advanced users rather than absolutely necessary?Thank you for the nuanced perspective! That’s exactly what I wanted to find out. I don’t have an extensive tool collection at home, but I also don’t want to force pieces together or risk damaging parts. Comfort and safety are important to me, but I’m also wondering if investing in specialized tools for a single piece of furniture is worthwhile.
Is there perhaps a kind of “minimal tool kit” that you would personally recommend, even if you don’t build furniture regularly? For example, just a hex key with a handle? Or is the one included definitely too weak?
I’m looking forward to your opinions!
The included Allen wrench is designed for occasional use, so it can handle all the necessary steps in principle. Issues:
- It is often too short and lacks a handle, making it harder to apply force.
- No torque limitation is possible with manual tools.
A simple, cost-effective improvement:
- Purchase an ergonomic 4 mm (5/32 inch) Allen wrench with a T-handle.
For the Brimnes, this is sufficient. A cordless drill is optional in this case but may be worthwhile if assembling multiple pieces of furniture.
Efficiency tip: Pre-insert the screws into the holes, then use the Allen tool to tighten them fully.
Additional to the previous recommendations:
The IKEA BRIMNES, due to its material (particleboard) and construction, is rather sensitive to over-tightening. Therefore, careful handling when screwing is essential.
A simple and safe method is to first tighten all screws only lightly, without applying much force, so that all parts are properly positioned. After that, perform the final tightening with moderate torque.
For users without a cordless drill:
- A long hex key with a good grip provides better leverage and reduces the risk of finger injuries.
Summary:
- Ergonomic 4 mm (5/32 inch) hex key
- Optional cordless drill with adjustable torque
- Rubber mallet for back panels
These tools not only improve assembly quality but also protect the material from damage.
Summary:
