ᐅ Are there any special tips for assembling the Ikea Brimnes furniture when doing it alone?
Created on: 27 Jul 2020 09:42
pita2
pita2
27 Jul 2020 09:42
Hello everyone, I am planning to assemble a Brimnes bed from Ikea by myself, as I won’t have any assistance and have mostly assembled furniture with two people until now. Since this Ikea furniture seems rather bulky and complex, I wanted to ask here if anyone has specific tips or proven methods for assembling this model alone. I’m particularly interested in topics such as handling larger components, the order of assembly, how to easily access and tighten screws, and whether there are any tricks for safely positioning and leveling the piece on your own afterward. I would be very grateful for any experiences and advice, as I want to build the bed as efficiently and neatly as possible, without stress or setbacks. Many thanks in advance for your helpful input!
sarlo
27 Jul 2020 10:17
Hello pita2,
I can understand that assembling the furniture alone can be a bit slow, especially with a larger piece like the Brimnes bed. Here are a few tips that helped me when assembling on my own:
- Take enough time and prepare everything in advance. Arrange all screws, tools, and parts in an organized way so you don’t have to search for them during assembly.
- For larger parts like the bed base or frame, I recommend laying them flat on the floor first to make working easier.
- A common tip is to only lightly screw in fasteners at first, without fully tightening them. This allows you to make small adjustments later during assembly.
- For parts you would normally hold during assembly, use clamps or objects like chairs for support if you don’t have a second person helping.
- A small tape measure and a spirit level often help to ensure everything is aligned and level.
Patience is important, and don’t get discouraged if something doesn’t work right away. The Brimnes bed is solidly built but can be a bit bulky. Good luck, and feel free to ask if you have more questions!
KODAN32
27 Jul 2020 15:49
Hello pita2,
I’ll briefly summarize the key points in a simple step-by-step guide that I generally follow when assembling Ikea beds alone and that should also specifically apply to the Brimnes:
- Step 1: Check all parts for completeness and sort all screws by type.
- Step 2: Read the instructions carefully, especially the order of the components, to avoid assembly mistakes.
- Step 3: Loosely screw together large panels like the side panels and headboard/footboard first, so adjustments are still possible.
- Step 4: To hold parts in place while screwing, temporary aids like packing tape or adhesive tape can be helpful.
- Step 5: Tighten screws gently at first and only fully tighten them at the end to ensure even stability.
- Step 6: Make sure not to install parts upside down, which can easily happen when working alone without a second perspective.
- Step 7: For positioning the bed, I recommend assembling the frame first and keeping it easy to move before adding the slatted base.
Common mistakes when assembling solo often involve holding parts in place and incorrect screw sequence. If you like, I can also send a list of recommended tools and aids.
One more tip: A large mirror or a smartphone to occasionally take photos from different angles can be helpful for checking alignment.
I hope this helps you!
pita2
28 Jul 2020 08:04
KODAN32 schrieb:
Typical mistakes during solo assembly often involve holding the components in place and using the wrong screw sequence.
You summarized that well, thank you! The topic of holding parts steady will probably be my biggest challenge. I’m also considering whether simple aids like wooden battens or small trestles could temporarily serve as supports. Has anyone in the forum used wooden items as provisional holders and can offer any recommendations?
Also, I’m curious if there are any special solutions for the Brimnes bed to join the large side panels single-handedly, or if it’s best to arrange for a second person. Thanks!
sarlo
28 Jul 2020 10:29
pita2 schrieb:
I’m also wondering if simple helpers like wooden slats or small trestles could temporarily serve as supports.
Yes, that’s a very good idea, and I can confirm it from experience. Wooden slats or small stools work great to support heavy side panels. In my case, I placed them right where I would have otherwise needed a hand to align the structure.
pita2 schrieb:
Has anyone in the forum ever used something wooden as a temporary support and can provide recommendations?
My recommendation:
- Use sturdy but not too thick wooden slats that can be wedged under the edges of the side panels.
- If necessary, add non-slip pads under the slats or directly on the floor to prevent slipping.
- Make sure the height of the support roughly matches the level you’re assembling, so you don’t have to constantly readjust.
If you don’t have wooden slats, thick books or boxes can also work, but be careful to keep everything level and stable.
Regarding joining the side panels: Ideally, you can first screw one of the side panels in place, then position the other with the help of the supports and gradually screw it step by step. This way, you avoid the problem of having to hold everything up on your own.
I hope this gives you a clearer idea of how to approach it.
