ᐅ Are there any special care instructions for IKEA Platsa surfaces?
Created on: 24 Aug 2021 16:23
HildeAre there any special care instructions for IKEA Platsa surfaces? I recently purchased a Platsa shelving unit from IKEA and am wondering how to best maintain the surfaces to preserve their appearance and functionality over time. Specifically, I am interested in recommendations regarding cleaning methods, suitable or unsuitable cleaning products, and tips on how to avoid common damages such as water rings or scratches. I would also appreciate information about any special care products recommended for Platsa surfaces or general precautions to take during cleaning.
Regarding your question about special care instructions for IKEA Platsa surfaces, there are indeed a few points to keep in mind to prevent damage and premature wear. Platsa furniture is often made of melamine-coated particleboard or painted surfaces.
- Cleaning: A soft, damp cloth is best, without using harsh cleaning agents. Avoid abrasive sponges or cloths, as they can scratch the surface.
- Cleaning products: Use pH-neutral all-purpose cleaners, and avoid solvents, bleach, or alcohol-based products. These can damage or dull the surface.
- Water stains often occur when water remains on the surface for a prolonged period. Therefore, wipe damp spots immediately and dry thoroughly.
- For scratches, gentle care with furniture polish or special repair kits can help, but since Platsa is relatively inexpensive, this is usually only worthwhile for larger damages.
Do you have more details about your material or the exact surface treatment of your furniture? That would help provide more specific care advice.
In addition to the points already mentioned: IKEA states that the surfaces of the Platsa series should be treated with care. Harsh chemicals should be avoided, and the furniture should be regularly cleaned with a soft, damp microfiber cloth.
It is recommended to remove stains promptly and avoid leaving any areas damp for extended periods to prevent swelling of the particleboard. Direct sunlight should also be avoided over the long term, as it can cause discoloration.
To prevent scratches, it is advisable to place protective pads under decorative items. In general, melamine-coated panels are more sensitive to mechanical stress than to chemical exposure.
Joshbe schrieb:
You should avoid using harsh chemicals and regularly clean the furniture with a soft, damp microfiber cloth.That sums it up well. One more technical note: melamine resin-coated surfaces are quite resistant to heat and moisture, but micro-scratches can develop quickly from abrasive particles or improper cleaning.
Therefore, it’s important to remove dust regularly to avoid accidentally causing scratches from dirt particles.
Once again, a question for you: Do you use your Platsa furniture piece in a kitchen, living room, or another environment? This significantly affects care and wear.
