ᐅ Are there any issues with using Ikea BRIMNES furniture in areas with high humidity or moisture?
Created on: 8 Jan 2022 18:37
mau58Hello everyone, I am planning to redesign my apartment and am considering using a piece of furniture from the Ikea BRIMNES series in a damp room. Specifically, it is the BRIMNES wall cabinet with doors, which is intended for bedrooms or living rooms. My question is: Are there any known issues with Ikea BRIMNES furniture, especially the wall cabinet, when placed in rooms with higher humidity, such as bathrooms or laundry rooms? I am mainly concerned about material warping, susceptibility to mold, or other types of damage that could occur due to moisture exposure. Does anyone have experience or advice on whether the BRIMNES series is suitable for such conditions or if other types of furniture would be more appropriate? Thank you in advance for your informed responses!
Hello mau58,
First of all, some basic information about the BRIMNES series: it mainly consists of particleboard with a melamine coating and plastic edges. Materials of this type are generally not ideal for use in wet rooms because they can absorb moisture, which may lead to swelling or deformation.
Typical problems include:
- Swelling of the edges due to moisture penetration
- Water stains and peeling of the coating
- Possible mold growth if air circulation around the furniture is poor and moisture accumulates
If you still want to use BRIMNES, I recommend:
- Avoid placing the furniture directly next to showers or washing areas
- Ensure sufficient ventilation, for example by airing the room or using an exhaust system
- Moisture-resistant materials such as MDF rated for wet areas or specially treated solid wood would actually be more suitable here
One last tip: If you decide to go with BRIMNES, make sure to leave some space from the wall and consider using silicone seals to prevent direct water contact.
I hope this helps!
mau58 schrieb:Here it becomes clear that other series specifically designed for bathrooms, made of plastic or with HPL surfaces, are significantly more durable.
Does anyone have experience or advice on whether the BRIMNES series is suitable for these conditions or if other types of furniture are better suited?
I hope this helps!
nera59 schrieb:
It mainly consists of particleboard with a melamine coating and plastic edges. Materials of this type are generally not ideal for use in damp rooms.This is certainly true; however, it is important to make a more specific distinction. Whether BRIMNES causes issues in damp rooms largely depends on how it is actually used. If the furniture is placed in a bathroom with high humidity but rarely comes into direct contact with water and has good ventilation, it may last several years without damage.
It becomes more critical when conditions exceed normal humidity levels, such as utility rooms with splashing water or inadequate ventilation. Particleboard quickly reaches its limits in these situations.
I believe it is important that manufacturers not only indicate that their products are not designed for damp environments but that buyers are also aware from the start that the lifespan in moist conditions is limited.
Therefore, I recommend as a precaution:
- Purchase furniture that is suitable for damp rooms
- Generally consider alternatives with higher moisture resistance
This discussion also highlights that the term “damp room” can refer to very different conditions. This should be taken into account during planning.
To add to my input, based on material testing and manufacturer information:
BRIMNES furniture is made from medium-density fiberboard (MDF) or particleboard coated with melamine resin. These coatings provide some moisture resistance but are not waterproof.
In rooms with high humidity or occasional water exposure, the following issues may occur:
- The material swells and loses dimensional stability.
- Edges, which often have only a plastic edge banding, tend to peel or crack.
- Protection against mold is limited because moisture can penetrate the material.
The relevant European standards for furniture include EN 301 for furniture panels. However, this standard does not explicitly cover use in wet rooms; it generally addresses moisture conditions in testing.
Conclusion: Ikea states that BRIMNES is not specifically designed for bathrooms or other wet rooms.
For use in wet rooms, furniture made from moisture-resistant MDF panels or plastic panels is significantly better suited.
If BRIMNES is used anyway, the furniture should:
- Not be exposed to direct splashing water.
- Allow for continuous air circulation.
- Be regularly checked for signs of material damage.
This minimizes risks, but problem-free use in wet rooms cannot be guaranteed.
