ᐅ Are there any issues that can arise when assembling or installing Ikea HEMNES furniture?
Created on: 8 Oct 2024 09:12
boubacar0
boubacar0
8 Oct 2024 09:12
I wanted to start a discussion: Are there any issues that can arise when storing items in Ikea Hemnes furniture?
I’ve noticed that when organizing my belongings in the HEMNES dressers, I occasionally encounter difficulties, especially regarding space layout and the maximum load capacity of the drawers. Particularly with more complex items or when using the drawers to store heavy objects, I wonder if other users have had similar experiences.
I am especially interested in the following points:
- Are there common mistakes to avoid when storing items?
- Are the drawers stable enough for regular use?
- What limitations exist concerning the layout or use of the compartments?
I look forward to your experiences and tips!
Jensson
8 Oct 2024 09:45
Hello boubacar0,
First of all, a great topic! From my experience, there are indeed a few things to consider when storing items in HEMNES dressers.
1. Load capacity: The drawers typically support up to 7 kg (15 lbs); regularly exceeding this weight can affect the construction.
2. Drawer slides: Be careful not to overload them or place sharp objects inside, as this can cause blockages or delay closing.
3. Organization systems: To optimize storage space, I recommend using smaller boxes or dividers inside the drawers. This helps prevent items from getting mixed up.
Summary: Avoid overloading and maintain a clear structure inside the drawers. If you follow these tips, you should have few problems.
Elijah42
8 Oct 2024 10:07
I have found that drawers tend to wear out faster when storing heavier items. So it’s best not to put anything too heavy inside.
RENMA
8 Oct 2024 10:33
The following issues may arise when storing items in Ikea HEMNES furniture:
- Load limits: Manufacturer specifications must be strictly followed. Consistently exceeding these limits can cause hardware damage to the drawers.
- Space utilization: The fixed dimensions of the drawers can be impractical for bulky or irregularly shaped items, reducing storage efficiency.
- Assembly quality: Improper assembly affects stability, which can lead to problems when opening and closing the drawers.
For optimal storage, it is also recommended to use divider systems from the Ikea accessories range.
Domau0
8 Oct 2024 11:02
I would like to explore this topic further and examine it from a technical perspective.
The HEMNES dressers are built with a solid pine wood frame, which is generally quite sturdy. However, there are some important points to consider when storing items:
- Drawer slides: These can be either wooden slides with single or double rails or metal runners. Wooden slides tend to warp or jam more easily when overloaded, especially in combination with moisture.
- Load capacity of drawer bottoms: The thin panels made of MDF or hardboard are not designed for consistently heavy loads. Overloading can cause bending.
- Humidity: Wood can expand and contract, meaning that at high humidity levels, the components may slightly deform, making the drawers harder to open and close.
Therefore, it is most practical to distribute medium loads evenly and avoid placing sharp-edged or heavy items inside without protective padding. Regular maintenance, such as tightening screws, can also help maintain proper functionality.
By the way, a quick question: Are you referring to the latest HEMNES version with the metal drawer slides?
boubacar0
8 Oct 2024 11:45
Domau0 schrieb:
Oh, one more question: Are you using the latest HEMNES version with metal drawer slides?
Thanks for the detailed explanations, Domau0; this kind of information is really helpful!
I have the standard version with wooden drawer runners, so I suspect that the issues with warping might indeed be related to the material.
I use the drawers quite often and have noticed that they can be a bit stiff at times, especially when I store many books in them. Would that fit with your assessment?
One more question: Is there a way to improve or replace the drawer slides to increase durability without having to buy completely different furniture?
