ᐅ Are there any common issues with the Ikea Hemnes range that new users should be aware of?
Created on: 12 Aug 2020 18:23
EllurenHello everyone, I am considering purchasing some furniture from the Ikea Hemnes series, especially dressers and wardrobes. Before I place an order, I would like to know from your experience if there are any particular issues or challenges with the Hemnes products that new users should be aware of. For example, are there weak points in the materials, difficulties during assembly, long-term durability concerns, or other details to know in advance to avoid disappointment? I would prefer not to be surprised later by the design or quality, so I’m relying on your realistic assessments. Thanks in advance for your feedback!
Hello Elluren, thank you for the precise question; it really helps to address it directly. The Hemnes series is generally very popular because it has a classic design and is comparatively sturdy. However, there are a few aspects you should consider:
- The pine wood is attractive but tends to warp slightly in high humidity, which can be noticeable especially on doors or drawers.
- Assembly takes a bit more time compared to some other Ikea series, as Hemnes often uses more wooden components and nails instead of just screw connections. Make sure to carefully follow each step of the assembly instructions.
- Due to the weight, you should ensure that furniture pieces are securely fixed – particularly tall cabinets.
- Over time, the white finishes can yellow slightly if exposed to strong sunlight.
If you are aware of these points and plan accordingly, you already have a good basis to avoid issues. If you want more details on assembly or care, feel free to ask!
PECLARISSA12 Aug 2020 21:14Hello Elluren! 😊 I completely agree with Raymond—the Hemnes is really popular and looks great in any room. But a small tip from me: the drawers can be a bit stiff at first, especially when fully loaded. However, this is usually just a matter of adjustment. Just tweak the drawer slides a bit, and they will usually run much more smoothly.
Also, from my own experience, the white lacquer finish tends to show fingerprints quickly—so maybe not the best choice if you have small children who like to wipe on the furniture. 😉 Otherwise, it’s excellent for the price and design!
Oh, and the assembly can easily take 2 to 3 hours, so make sure to have enough coffee ready!
Interesting perspectives so far, but I would like to add a critical point: The durability of the Hemnes series is often praised, but this is usually based on superficial experiences over 1–2 years. There are reports indicating that the wood joints, especially under frequent use, lose stability more quickly and show signs of fatigue after about 5 years.
Furthermore, I would question the choice of material, since pine wood, while attractive, is noticeably softer and therefore more prone to dents or scratches – which is quite relevant for heavily used furniture.
I find this point very important. So, if you live in a home with high humidity levels, for example, an older building without modern climate control, it might be better to choose other furniture series or wait for long-term testing.
Raymond schrieb:
Pine wood is attractive but tends to warp slightly in high humidity, which can be noticeable especially in doors or drawers.
Summary of the main issues with the Hemnes series, based on technical data and user reports:
- Material: Hemnes primarily uses solid pine wood, which is visually appealing but soft and prone to mechanical damage such as scratches and dents.
- Construction: The furniture is partly assembled with glue and nail joints, which can affect stability with frequent use.
- Assembly: Relatively time-consuming; a detailed instruction manual is essential.
- Moisture sensitivity: The wood can swell or warp if ventilation is insufficient or humidity is high, reducing the fit of doors and drawers.
- Surface care: White paint finishes may yellow when exposed to sunlight.
Additionally, I recommend viewing a sample dresser or an already assembled Hemnes unit in person to get a sense of the workmanship. These are generally typical characteristics of solid wood furniture in this price range, but it is important to be aware of the potential challenges.
If you choose Hemnes, pay special attention to the order of the screws during assembly. Tightening them too early can cause problems later on. Wood expands and contracts, so it’s better not to tighten them too firmly.
Regarding humidity: ventilating helps, and it’s best not to place it in the bathroom or basement.
