ᐅ Are there any known weak points in the IKEA Brimnes construction?
Created on: 30 Mar 2018 10:37
BlamertHello everyone,
I am currently looking into the IKEA Brimnes series, especially the wardrobes and dressers, and I wanted to ask specifically: Are there any known weaknesses in the IKEA Brimnes construction that buyers should definitely be aware of before purchasing?
I’m not looking for general criticism of IKEA, but rather constructive points, such as issues with stability, material fatigue, or common assembly mistakes that occur more frequently in practice.
I have recently read from some sources that the back panels may warp or the fittings may not last long. If anyone has personal experience or reliable information, I would really appreciate hearing about it.
Thanks in advance for your insights!
I can only say: The back panels on the Brimnes are often a weak point. They are thin and tend to warp, especially when the furniture is placed directly against a wall that is not completely straight.
Also, the screws at the joints sometimes loosen with frequent use. Otherwise, the system holds up well under normal load.
flo-Theres30 Mar 2018 14:49Regarding the weaknesses in the IKEA Brimnes construction, there are several points that should be considered in more detail.
First of all: The main issue often lies in the sizing of the back panels, as already mentioned. These are usually made of thin MDF or hardboard material, which can warp due to moisture or tension. This sometimes leads to so-called "cupping" and affects the stability.
In addition, the metal fittings used in Brimnes are suitable for standard loads, but with intensive use or frequent self-assembly, the connections can loosen over time – regular inspections are recommended here.
Another point concerns the hinges on doors and flaps: Some users report that these become slightly loose after some time, which can usually be fixed easily by readjusting the screws.
For home use, however, these are not major obstacles, and with some care and possibly additional reinforcements, the durability can be significantly improved.
flo-Theres schrieb:
The main issue often lies in the dimensioning of the back panels, as already mentioned.I see this quite differently. The question is whether the material itself is a weak point or rather the overall construction.
In my opinion, using a thin back panel is a deliberate cost and weight saving measure and, if used properly, not automatically a design flaw. I find the way the joints between the side panels and shelves are made to be more critical – sometimes there is a lack of sufficient doweling or sturdy metal connectors, which can lead to damage from repeated assembly and disassembly.
Furthermore, I would question whether all users strictly follow the recommended torque settings during assembly – too much or too little force quickly has negative effects.
Therefore, calling it a “known weak point” is an oversimplification. It is more important to differentiate between the duration of use, assembly discipline, and product design.
Neogi schrieb:
So calling it a "known weak point" is a bit of an oversimplification.That made me smile a bit – sometimes we all tend to treat our home furniture as a lifelong masterpiece 😄
But jokes aside, I think Brimnes is actually quite well made for its price range. Of course, you don’t get the durability of solid wood; engineered wood products are always a compromise.
Issues with back panels or hinges are definitely not a total failure but rather typical signs of wear you can expect with heavy use. If you’re a bit more careful during assembly, you can probably avoid most problems.
Those who want extra security can reinforce critical points themselves with a few small braces – for example, additional corner brackets on the back panel. That will last for years. In that sense, Brimnes doesn’t have weaknesses due to poor craftsmanship, but rather because it’s balancing low prices with acceptable quality.
