ᐅ Are there any known safety issues with Ikea BRIMNES furniture?
Created on: 24 Jul 2021 14:37
Le-ayseHello everyone,
I recently purchased some Ikea Brimnes furniture for my bedroom and came across reports warning about potential safety issues, such as stability problems or the risk of tipping—especially with dressers and cabinets from this series. I am interested to know if anyone in this forum has solid experience or official information that can confirm whether BRIMNES furniture actually has any safety-related defects during use.
Specifically, I am interested in:
- Are there known incidents or recalls concerning the stability or assembly of BRIMNES furniture?
- Are there design aspects that should be considered critical, for example regarding wall anchoring?
- Does anyone have practical advice on how to use this furniture safely or retrofit it if there are gear or mechanism problems?
It would be great if some professionals or experienced users could share their insights. Thanks!
Le-ayse schrieb:
I recently bought some Ikea BRIMNES furniture pieces for my bedroom and came across several reports warning of possible safety issues, such as stability problems or the risk of tipping—especially concerning dressers and cabinets in this series.I find it important to always check the source of such reports. Ikea is known for its extensive testing; however, with affordable furniture, minor weaknesses can sometimes occur. Are the reports you’re referring to consumer warnings, forum opinions, or official recalls? Without specific details, it’s difficult to assess the safety risk in general.
Le-ayse schrieb:
Are there any known incidents or recalls related to the stability or assembly of BRIMNES furniture?I have not found any official recalls on this matter. Still, some users in various online forums mention that assembly instructions can sometimes be misunderstood, leading to an unsafe construction. My recommendation is to pay close attention to securing the furniture to the wall during assembly. BRIMNES dressers, in particular, can be prone to tipping if they are not properly anchored.
Regarding construction details: the series mainly consists of particleboard with a melamine coating—which is durable but can swell or crack if handled improperly or exposed to moisture, reducing stability.
If anyone knows of specific accidents or official updates, please share.
theo63 schrieb:
I have not found any official recalls regarding this. However, some users in various online forums report that the assembly instructions are sometimes misunderstood, which can lead to an unsafe construction.This is a crucial point that I would like to explore in more technical detail. Ikea uses simple plug-and-screw connections for the BRIMNES series. The components are often relatively thin, which keeps the design sleek, but this can naturally cause issues under heavier loads.
An important safety aspect of the BRIMNES chest of drawers is attaching the included wall anchors. Without these, there is a general risk of tipping, especially in households with children or when drawers are frequently fully extended. The assembly manual does explain this step, but as theo63 mentioned, it is often ignored.
Technically speaking:
- The wall attachment relies on plastic wall plugs and short screws for fixation. If the wrong plug size is chosen, or if the wall materials (e.g., drywall vs. solid walls) are not taken into account, the fixation may come loose.
- The particleboard panels of the BRIMNES are industrially pressed, which ensures good stability, but the edges are often the weakest points. These edges are particularly sensitive to moisture or improper handling.
In addition to secure anchoring, I recommend not loading the furniture with more weight than specified in the technical data. Checking the screws after some time is also advisable to detect material fatigue early.
I am interested to know if anyone here has experience with alternative anchoring methods or tips for reinforcing the furniture?
Thierryzar26 Jul 2021 12:58There are no official recalls for Ikea BRIMNES due to safety issues.
Important: Always secure furniture to the wall as recommended by Ikea.
Ensure correct assembly and avoid exceeding the weight limits.
This significantly reduces risks.
