ᐅ Are there any known defects or issues with the IKEA Brimnes furniture?
Created on: 15 Jun 2021 10:07
kaupa
kaupa
15 Jun 2021 10:07
Hello everyone, I am planning to get an IKEA Brimnes bedroom furniture set because I find the design and price-performance ratio very appealing. Before I make my final decision, I would like to hear from you: Are there any known defects or weaknesses with the IKEA Brimnes furniture, especially regarding quality, durability, or assembly? I am particularly interested in issues that arise with long-term use or typical difficulties during installation. Maybe someone has specific experiences or reports I should be aware of.
pauPierce
15 Jun 2021 11:42
The IKEA Brimnes range has some well-known weaknesses that I’d like to explain in more detail since you asked for specifics. First, it’s important to know that Brimnes furniture is mainly made from medium-density fiberboard (MDF) with a laminated surface, which makes it relatively susceptible to moisture. While this is usually less critical in bedrooms than in kitchens, the edges can sometimes be sensitive to water splashes or improper cleaning.
Another issue is the assembly system: many people have reported that connection points, especially on larger wardrobes and bed frames, can loosen over time under stress. This means screws may come loose or dowels may not hold firmly enough, which can occasionally cause minor wobbling or creaking.
Additionally, the fittings and hinges are not made from particularly high-quality materials; after several months of frequent use, opened and closed drawers often show initial signs of wear. I could ask further: do you mainly use the Brimnes models for wardrobes, beds, or dressers? The weaknesses vary somewhat depending on the item type.
kaupa
15 Jun 2021 11:54
pauPierce schrieb:
I could follow up: Do you mainly use the Brimnes models for wardrobes, beds, or dressers? The weak points vary a bit depending on that.
Thanks for the detailed answer! My main focus is the wardrobe and possibly the bed frame. So I primarily need a durable solution for storing clothes, and the bed frame should be stable but also comfortable. How are the drawer slides and load limits in that regard? It’s important to me that nothing breaks with frequent use.
mo-hau
15 Jun 2021 13:17
Regarding the Brimnes wardrobe, I can share the following based on facts: The hanging rods are made of metal and are generally load-bearing up to about 20 kilograms (44 pounds), which is sufficient for regular-weight clothing. The drawers run on rollers, which can wear down over time with heavy use, especially when fully loaded. Regular cleaning of the drawer tracks helps keep the mechanism running smoothly.
The bed frame (Brimnes) is fundamentally stable in construction but does not offer any suspension, which may be a drawback for people who prefer a flexible sleeping surface. The connectors can give slightly under sudden stress. It is advisable to check and, if necessary, tighten the screws again after a few months.
The material itself, as pauPierce mentioned, is MDF with a coating, which is sensitive at the edges and can swell when exposed to moisture. Overall, Brimnes is best classified as a solid furniture system in the budget segment, without exceptional durability.
Eleanor
15 Jun 2021 13:45
I have had the Brimnes wardrobe for about 2 years. In my experience, the drawers can be somewhat difficult to open, especially when fully loaded. The wood shows slight wear on the edges, but nothing that significantly affects its use.
Genevieve
15 Jun 2021 15:09
It is interesting that you mentioned the assembly quality and the condition of the materials. But how reliable are these experiences? Do these defects actually affect the service life, or are they more cosmetic issues?
pauPierce schrieb:
Many acquaintances report that the joints, especially in larger cabinets and bed frames, tend to loosen somewhat over time under load.
This sounds more like an assembly issue than a design flaw or material deficiency. Could careful assembly or adjustment provide a solution here?
At the same time, I consider that IKEA might deliberately promote a sort of disposability mentality through limited quality, but compensates with low prices. This would be a relevant counterargument regarding durability.
