ᐅ Are there any useful tips or hacks for repairing the MALM nightstand?
Created on: 19 May 2017 08:27
Soruko
Soruko
19 May 2017 08:27
I recently bought a MALM nightstand from IKEA, which, due to its construction and the commonly used particleboard material, tends to develop minor damage under heavy use, such as chipped corners, loose joints, or broken edges. Therefore, I am very interested to know: Are there any useful hacks or repair methods beyond the usual application of glue that can practically and sustainably restore the MALM nightstand? Techniques that can be done with simple tools at home and also respect the design would be especially welcome. Does anyone have experience or tips on how to cleverly repair or even reinforce these typical weak points?
V
vinli
19 May 2017 09:45
The question about effective repair methods or hacks for the MALM nightstand is definitely valid, as the material (particleboard with a foil coating) is prone to mechanical damage.
A common and effective approach is to use wood glue combined with clamps to securely reattach split edges. Additionally, applying matching edge banding (PVC or real wood veneer) to damaged areas is recommended; this can be applied using an iron and heat to maintain the appearance.
For deeper repairs on chipped or broken sections, a two-component wood filler can be used, which can later be sanded and color-matched. Although this requires more time, it results in an almost invisible repair.
A lesser-known but practical hack is reinforcing the structure with small metal corner braces or L-brackets on the inside, which increases stability without affecting the look of the outer surfaces.
O
ONRONA
19 May 2017 10:33
vinli schrieb:
A common and effective method is combining wood glue and clamps
That is generally correct, but with particleboard, the moisture from the glue often has a negative effect – the material swells and becomes even more vulnerable. Therefore, it is essential to use a waterproof adhesive suitable for particleboard.
vinli schrieb:
Reinforcement with small metal angle brackets/L-brackets on the inside to increase stability
In my opinion, this is a very practical approach, but one must not forget that this may affect the back panel, which in turn slightly reduces storage space. Additionally, it is important to ensure that the brackets do not spoil the appearance in visible areas.
Overall, I find the question good because the MALM series is often purchased, but there are few documented repair solutions. It might also be interesting to know to what extent people use third-party furniture repair kits, for example.
JUANFU
20 May 2017 07:12
Wow, that’s really great! 🙂 The tip about the two-component wood fillers really surprised me—I didn’t know about that at all. I had always just used glue and then got frustrated because the spots would open up again.
Recently, I treated my nightstand a bit roughly, and luckily I had some filler compound at home that I used to repair the broken area. After sanding and applying some paint, it looks almost like new!
One more tip from me: if you like more color, you can even touch up the repaired spots with colored wax crayons or furniture markers. That gives the piece of furniture a unique touch.
Please keep these coming—practical hacks like this are really helpful! 👍
Shawn38
20 May 2017 09:54
Soruko schrieb:
Are there any interesting hacks or repair methods beyond the usual glue application that can practically and sustainably restore the MALM nightstand?
I think it’s important to identify the cause of the damage before repairing: Is it due to transport, assembly issues, or everyday wear and tear?
For loose joints, tightening the screws with the appropriate tools usually helps. If the threaded insert in the particleboard is damaged, using wood thread inserts can significantly improve stability.
For chipped edges, besides the previously mentioned wood filler, a tempergard or furniture repair wax works well. You simply melt a small amount and press it into the damaged area. It is very flexible and looks clean after it hardens.
Additionally, cleaning and caring for the surface with furniture oil or wax can extend its lifespan. Although MALM nightstands have a coated finish, occasional maintenance is still beneficial.
If needed, I’m happy to provide detailed instructions and product recommendations.
