ᐅ Are there any experiences with the durability of IKEA Platsa systems after several years?
Created on: 30 Dec 2024 08:23
farlinus
Hello everyone, I am planning to purchase an IKEA Platsa wardrobe system for my bedroom, and possibly also for the hallway. Since I place a lot of value on durability and sturdiness, I would like to know in advance: Do you have any experience with the longevity of IKEA Platsa after several years of use? I am especially interested in aspects such as the stability of the construction, material quality (panels, hinges, drawer slides), and whether there are common signs of wear or weak points that appear after 3, 5, or even 10 years. It would also be important to know how the system holds up with frequent use, such as daily opening and closing. Are there perhaps different experiences depending on the location or assembly? Thank you in advance for your detailed opinions and tips!
A few additional details: When assembling IKEA Platsa units, careful installation is important because the panels use a relatively large number of connectors and screws, which can wear out faster if not assembled precisely. Furthermore, the paint or coating is quite thin, so sharp edges may wear down over time with frequent use. Regarding stability, it has been observed that the lower modules tend to be more durable—shelves or fronts attached above can become loose over time. A tip: For long-term use, it is worth tightening the screws again after 1-2 years.
Domau0 schrieb:
How intensively do you use the cabinets? Are they heavily loaded or mainly for clothing? Are there any damp areas in the apartment that should be considered? Thank you very much for your detailed response, Domau0. The cabinets are mainly planned for storing clothing and a few household items, so no excessive loading with heavy objects. Moisture is not an issue in the bedroom, rather normal room temperature and humidity. I think the load will be average – frequent opening and closing, but no heavy weights. Do you think using Platsa is suitable in that case? Or should I rather look for alternative systems that might seem a bit more solid?
farlinus schrieb:
Do you think using Platsa makes sense then? Or should I rather look for alternative systems that might appear more solid? For the usage you described – clothing, moderate load, dry environment – Platsa is suitable. The system stands out for its modularity and adaptability at a good price-performance ratio. A small tip: ensure a sturdy assembly and tighten the screws again after about one year. Alternatively, solid wood furniture is naturally more durable but usually costs significantly more and offers less design flexibility. If you value flexibility, Platsa is a practical choice.
farlinus schrieb:
Do you think using Platsa makes sense? Or should I look for alternatives, maybe something that feels a bit more solid? I think Platsa is great! I’ve had it for years and am really happy with it. Especially if you’re not dealing with extreme loads, it holds up well. You can also upgrade it a bit with different fronts and interior layouts! Of course, if you want something for life, solid wood is great—but it costs more. Platsa is still a real all-rounder even after years.
In addition to the points mentioned: Pay attention to how your Platsa modules are connected. Stability increases significantly when multiple modules are screwed together. This prevents tipping or drifting apart during use. It is also advisable, if possible, to properly secure the back panels – they provide additional stability.
