ᐅ Are there any experiences with MALM home renovations?
Created on: 16 May 2015 18:17
Thaddeusmo
Hello everyone, I am currently considering modifying my IKEA Malm desk because the original offers too little storage and flexibility for my needs. Has anyone here had experience with Malm desk modifications? I am particularly interested in which materials and tools have proven effective, how simple or complex the modification is for non-professionals, and whether any specific technical challenges have come up (e.g., stability, surface treatment). Any advice on extensions like cable management or ergonomic adjustments would also be appreciated. Thanks in advance for your tips and feedback!
SIAURORA
17 May 2015 21:18
I think Malm modifications are often overestimated. The furniture is not designed to be heavily altered, which quickly leads to stability issues. If you want a sturdy piece of furniture, it’s better to buy a model that is suitable from the start. Modifications are more of a pastime and add little real value, unless you specifically want to showcase your DIY skills.
ixlu1 schrieb:
The pride afterward is unbeatable!
Pride, yes, but not in the quality.
alvalo
18 May 2015 08:44
I understand your desire for custom modifications, Thaddeusmo, and I can also see SIAURORA’s concerns. However, I have often seen good results when small improvements like additional shelving levels or cable pass-throughs are planned while largely preserving the original structure. It is important to keep an eye on the load-bearing points and not remove too much material. If you have experience using a cordless screwdriver, drill, and sanding tools, this approach can work well. For the surface, I recommend sealing it with clear varnish to protect the veneer.
ANFIKE
18 May 2015 12:29
One more tip: For cable openings, a simple hole saw used with a drill stand works very well. Although this requires some equipment, the result is very clean.
Thaddeusmo
18 May 2015 19:53
Thank you for your previous assessments and tips! The advice on tools and surface treatment has been especially helpful. I have one more question: Does anyone have experience installing drawer slides under the MALM panel? I believe this could significantly improve storage space, but I am not sure how difficult the installation is or whether it would affect the stability of the table. It would also be useful to know what height can realistically be used there. Thanks!
geneda
19 May 2015 07:28
Thaddeusmo schrieb:
Does anyone have experience installing drawer slides under the MALM top panel?
Yes, it is possible, but you need to reinforce the supporting frame. I recommend attaching sturdy wooden battens on the sides to mount the drawer slides. The height depends on the foot height or the surface area for support. It is important not to overload the slides, as the structure could become unstable. It is advisable to create a sketch beforehand and measure carefully. If you follow these points, you can significantly increase your storage space.
ixlu1
19 May 2015 17:04
geneda schrieb:
It is advisable to create a sketch beforehand and measure precisely.
Absolutely, without a sketch you can quickly lose track! I installed the drawer slides myself and attached two narrow drawers underneath the MALM top panel. 🙂 A real eye-catcher! Make sure the runners are installed straight. Then it works perfectly, and you get a lot of extra space!
