ᐅ Are there any experiences or feedback on which Malm models are particularly sturdy?
Created on: 22 Nov 2022 18:37
dagu42
dagu42
22 Nov 2022 18:37
Hello everyone, I am currently researching the different models of the Malm wardrobe from Ikea and wondering if there are any reliable experiences regarding which Malm models are particularly stable. I am especially interested in practical everyday use — for example, whether certain versions (such as tall dressers versus low drawer chests) tend to wobble less, become brittle, or warp less over the long term. Are there any insights on how the different construction methods, materials, and load capacities affect day-to-day durability? Specifically, which Malm models have you found to be especially stable and which less so? I look forward to well-supported, fact-based answers, as I am about to make a purchase and want to plan for the long term.
Taubi
22 Nov 2022 19:05
I would say the lower Malm dressers are more stable. The taller ones tend to be a bit wobbly on uneven floors. The wood quality is generally average but acceptable for the price.
gesar32
22 Nov 2022 21:43
Regarding the stability of the Malm models, user reports generally indicate that the wider and deeper versions, especially the 6- and 9-drawer dressers, are more stable due to their larger footprint and reinforced base panels.
Taubi schrieb:
The lower Malm dressers are more stable.
I agree with this assessment, as the lower models have less leverage and are less prone to tipping.
It should also be noted that all Malm models are made from particleboard, which is particularly susceptible to deformation under excessive load or moisture. The screws securing the back panel and sides provide some stabilization, but these must be assembled correctly to ensure stability.
My advice: For especially sturdy furniture, choose wider, low-profile Malm models and pay close attention to proper assembly.
theo63
23 Nov 2022 08:22
I find the question about the stability of Malm models interesting, but there is a lack of clarification about what exactly is meant by “stable”: resistance to tipping? Durability of the drawer slides? Material fatigue?
dagu42 schrieb:
I am mainly interested in practical everyday experiences – for example, whether certain versions tend to wobble less, become brittle, or warp over long-term use.
These aspects are certainly relevant, but the influence of usage should also be considered. For example, tall Malm dressers with drawers that are frequently fully extended are more prone to load-related issues due to leverage forces. At the same time, the construction itself plays a major role: an incorrectly assembled carcass can quickly feel unstable even if the model itself is suitable.
I find statements about a general “most stable Malm model” questionable, since stability should always be assessed in the context of usage, inspection of wall anchoring (often underestimated!), and the base surface.
letar
23 Nov 2022 13:59
Experience with the stability of the Malm series shows that the 6- and 9-drawer dressers are the most stable due to their dimensions and the broad base plates.
gesar32 schrieb:
The wider and deeper variants... are more stable.
I agree with this assessment, which is also confirmed by tests checking the tipping resistance and the load on the fasteners.
The carcass panels are made of medium-density fiberboard (MDF) with a decorative foil, which ensures a certain dimensional stability, but the material is sensitive to moisture. Combined with the low thickness of the side panels, this leads to a higher susceptibility to warping or wobbling in taller models.
Therefore, my recommendation when choosing is: if possible, select a model that is low to the ground and wide, ensure proper wall anchoring, and carry out the assembly carefully.
boelnu
24 Nov 2022 10:17
I would like to add that I initially experienced stability issues with my tall Malm wardrobe. Since my floor is slightly uneven, the piece of furniture was a bit wobbly, which made me feel uncertain at first.
theo63 schrieb:
Taller Malm dressers with frequently extended drawers are more prone to load-related problems.
After installing small furniture wedges under the wardrobe feet and, most importantly, securing it to the wall, the problem was largely resolved. For me, a stable fixation to prevent tipping is crucial, especially in households with young children.
I believe that, besides the model choice, user stabilization plays a major role. Therefore, I agree with the view that it’s not only about which model is more stable but also about how you handle the situation.
