ᐅ Are there any DIY projects for remodeling IKEA PLATSA?
Created on: 19 Nov 2021 14:07
libla50
libla50
19 Nov 2021 14:07
Hello everyone, I am currently looking into whether there are any DIY projects or guides specifically focused on customizing IKEA Platsa furniture. I am particularly interested in practical tips and creative ideas for personalizing the pieces, such as modifications, new finishes, or converting them into different types of furniture. Does anyone have experience with this or know of any instructions that help enhance Platsa components both functionally and visually? Perhaps there are also specific aspects to consider related to this system, for example regarding assembly or material properties. I look forward to your advice and recommendations!
Wesley
19 Nov 2021 15:28
Hey, great question! 😄 PLATSA is a really versatile system that allows for a lot of possibilities. From what I’ve seen, people build all kinds of things with it – from sideboards and shelves to hidden drawers. Sometimes the surfaces are enhanced with laminate or paint, but it’s important to prepare them properly to ensure good adhesion. It’s also crucial that the screws and joints remain stable when modifying the pieces, which sometimes means drilling holes in different spots or adding extra reinforcements. Overall, I think PLATSA provides a fairly sturdy foundation for creative customizations – you just need a bit of patience and a willingness to tinker!
Takutau
19 Nov 2021 17:03
Hello libla50, regarding your question: Yes, DIY projects involving IKEA PLATSA are quite common since the system is modular and relatively easy to work with. The advantage is that the individual modules are often compatible with each other, which makes modifications – such as adding doors, drawers, or using different handles – easier. For surface treatment, keep in mind that the panels often have a melamine coating, which makes painting or applying adhesives more challenging. I would recommend researching in advance which materials work best for remodeling, such as special adhesive films or paints designed for smooth surfaces. If you need help with assembly or tips on tools, feel free to ask!
PLOMA
20 Nov 2021 09:42
For additional information: When it comes to modifying IKEA PLATSA, it is important to thoroughly understand the construction method. The furniture is built around a relatively thin particleboard frame covered with melamine foil – this limits mechanical alterations because the panels can be brittle and prone to chipping. When painting, a primer treatment is necessary to roughen the surface and make it suitable for paint adhesion. If you are modifying drawers or doors, exact measurements must be followed to avoid problems during assembly. A common DIY trick is adding decorative moldings or baseboards, which can be custom-cut to give the piece a more refined appearance. It would be interesting to know whether you are focusing more on visual redesign or functional modifications? Do you have a specific project in mind?
libla50
20 Nov 2021 11:17
PLOMA schrieb:
It would be interesting to know whether you are focusing more on cosmetic redesign or functional modifications? Is there a specific project planned?
Thanks for the detailed information! My main goal is to make an existing PLATSA shelving system feel more homely and personalized. Specifically, I want to change the surface finish (color or overlay) while also adding functional elements such as internal drawers and possibly concealed cable management for electronics. I understand this requires a lot of precise work, especially concerning gap tolerances. Are there any standard solutions or tips to effectively combine both aspects? How can I ensure the furniture does not lose stability?
LOJOPAR
20 Nov 2021 18:39
Here is a brief guide that might help you with your project:
- Preparation: Thoroughly clean and sand surfaces before applying adhesive film or paint (use fine 240-grit sandpaper). If painting, it is recommended to use a special primer for better adhesion.
- Adhesive Film Application: Instead of cutting the film yourself, buy pre-cut adhesive sheets designed for furniture – they adhere better and can be applied with a precise fit.
- Functional Integration: For drawers, telescopic slides are often suitable and can be installed if the internal depth is sufficient. Make sure to follow the installation instructions carefully to align the slides correctly.
- Cable Pass-Throughs: These can be created using special plastic tubes or rubber-lined openings inserted into pre-drilled holes. Important: Never drill holes too close to the edge to avoid tearing out.
- Stability: To increase load-bearing capacity, you can add steel brackets or wooden battens inside, secured with screws from the inside. This does not affect the appearance but provides extra stability.
Feel free to ask if you need more details on any of the steps.
