ᐅ Are there any clever DIY solutions for IKEA Brimnes that you would recommend?
Created on: 22 Oct 2022 14:37
Dofatih
Dofatih
22 Oct 2022 14:37
Hello everyone, I’m looking for clever DIY solutions or modifications for the IKEA Brimnes furniture range, especially for cabinets and dressers. My goal is to enhance functionality or improve the appearance without making it too complicated or using expensive special parts.
Does anyone have practical DIY ideas that fit well with the Brimnes style and also optimize the storage concept? For example, smart organizers, special inserts, lighting ideas, or structural adjustments that go beyond simple decoration.
I look forward to your experiences and practical tips, including any advice on what to watch out for during modifications to avoid compromising stability.
lalutau
22 Oct 2022 16:05
A proven DIY solution for Brimnes dressers is to install drawer inserts made of wood or plastic to better organize the storage space. It is important to pay attention to the exact internal dimensions to cut the inserts to fit precisely.
Another common upgrade is the installation of LED light strips inside, preferably with a sensor that turns them on when opened. This improves visibility and gives a high-quality impression.
For the appearance, painting or applying adhesive film to the fronts is recommended, with a matte or satin finish to maintain the typical style. A small tip: before painting, lightly sand the surface so the paint adheres better.
In general, avoid making changes to load-bearing elements to preserve stability, especially keeping the back panel and sidewalls intact.
liRaul49
23 Oct 2022 09:12
I attached small furniture feet to my Brimnes dresser. This makes it easier to clean underneath and gives it a more modern look.
I also recommend storage baskets or boxes that fit into the large compartments to keep things more organized. It shouldn’t be too elaborate, though, as that would reduce the cost advantage of IKEA.
LOJOPAR
24 Oct 2022 12:48
Regarding clever DIY solutions for IKEA Brimnes, I would like to suggest a flexible step-by-step guide that is easy to follow:
- Step 1: Measure the internal dimensions precisely to ensure every addition fits perfectly.
- Step 2: For better organization, create drawer inserts from sturdy plywood or plastic. You can either order custom-made inserts from hardware stores or cut them yourself with a jigsaw.
- Step 3: The back panel can be covered with a thin, colored wallpaper or film to give the furniture a personal touch without compromising stability.
- Step 4: For improved lighting, I recommend slim LED strips with integrated motion sensors. These can usually be attached with double-sided tape.
Common mistakes I often see are overloading the dressers with additional heavy inserts or removing the back panels, which significantly reduces stability. Also, when modifying the fronts, avoid using materials that are too thick, as this can make the drawers hard to open.
In conclusion: The flexibility of IKEA Brimnes can be well utilized with some basic DIY skills without needing expensive special parts. If you decide to modify it, I recommend having a precise plan before cutting or assembling anything.
