ᐅ Are there alternative handles available for Ikea PLATSA besides the standard ones?
Created on: 1 Jan 2021 14:37
LeobrianHello everyone, I am currently considering how to customize the handles on my Ikea Platsa system, as I personally do not like the standard handles from Ikea. Are there any recommendations or experiences in this forum regarding the use of alternative handle models for Platsa that go beyond the typical Ikea range? I am particularly interested in the mounting options, since the design and modularity of Platsa fronts play a special role.
I would appreciate suggestions from both the Ikea range and third-party suppliers, including tips on installation or compatible alternatives.
Yes, PLATSA handles can be easily replaced. Just make sure the screw length matches the panel thickness.
Alternatively, you can use handle strips or handleless push-to-open systems.
Many third-party manufacturers also offer compatible handles; simply compare the drilling distances.
The question about alternatives to the standard handles for Ikea PLATSA can be answered in a nuanced way. Essentially, PLATSA fronts use a classic handle drilling pattern, which technically simplifies the installation of compatible third-party models.
When choosing an alternative handle, it is important to consider the drilling distance, which for Ikea standard furniture is usually 128 mm (5 inches), matching the standard sizes of many hardware manufacturers. Before purchasing, it is advisable to measure the exact thickness of your front panel, as some handles require longer screws, especially if you modify the fronts with additional adhesive films or paint.
Another option is to switch to handleless systems, such as push-to-open fittings, which allow for a completely different design and emphasize a modern, minimalist look. However, you need to ensure that the PLATSA fronts are mechanically compatible and that the correct fittings are used.
In addition to the Ikea standard, various online suppliers offer handle variants specifically adapted for modular systems like PLATSA. These often come in materials and colors of higher quality than the Ikea handles. Options range from metal and leather handles to simple wooden strips. However, you should always check whether the mounting holes match or if new holes will need to be drilled — this can affect the stability of the front.
One last note: the drillings on PLATSA fronts are usually visible, so a clean finish when changing handles is especially important to achieve a high-quality result. It would be interesting to know exactly what your PLATSA configuration looks like in order to provide more targeted recommendations. Are you using standard fronts, sliding doors, or larger cabinet elements?
I can confirm the statements by SAWYERR and kibutar.
- Check the screw length
- Standard drill holes are usually compatible with third-party handles
- Push-to-open is a good handle-free alternative
Those who want to be on the safe side should measure the dimensions precisely and, if necessary, opt for adjustable handles.
kibutar schrieb:
the installation of compatible third-party models is technically simplifiedI find it interesting that compatibility is often questioned, but Ikea appliances usually have fairly standard dimensions, allowing for a wide range of options. However, it is important to critically consider whether simply replacing the handles is always the best solution.
Standard handles are often designed for ease of use and economical production. If you want to focus on design and functionality, you should also check how different handle types affect the durability and ease of opening for PLATSA.
Push-to-open is an elegant solution, but it also involves higher costs and potential maintenance requirements. It would be useful to look more closely at the specific usage scenarios here.
Additionally, it’s important to ask whether the material quality and strength of self-made or third-party handles are sufficient, especially in households with children or frequent use.
I would like to know if the person asking the question aims to optimize functionality or only seeks a visual adjustment. The priorities differ significantly in these cases.
