ᐅ Are there alternatives to the original assembly of Ikea Brimnes?
Created on: 7 May 2020 09:13
PRA59
PRA59
7 May 2020 09:13
Hello everyone, I plan to assemble an Ikea Brimnes furniture piece but am unsure if the original Ikea assembly instructions are the only or best option. My question is: Are there any practical, proven alternatives to the original Ikea Brimnes assembly method that might be more stable, faster, or offer other advantages? I don’t just mean variations in the order of assembly, but actually different techniques, tools, or materials that users have successfully applied. It would be helpful if you could share your experiences or point out possible alternatives to make the assembly either more efficient or more durable.
Tobias
7 May 2020 09:52
There is usually no alternative to the original installation, as Ikea designs the construction and fastenings specifically for the material. You might be able to use screws with a larger diameter, but this carries risks. It is best to follow the instructions carefully.
O
onMarcos
7 May 2020 11:09
I can break down the question to address it more effectively. First: The original assembly of Ikea Brimnes uses simple dowels and screws designed for the MDF melamine-coated material. Alternatives could be:
- Using specialized wood screws with a larger thread to provide better grip
- Adding metal corner brackets for additional stability support
- Applying wood glue at critical joints to increase strength
It is important that such modifications do not damage the material or affect the fit. Common mistakes include overtightening screws or drilling holes that are too large. So my advice: If you choose an alternative fastening method, build a test assembly first before securing everything permanently.
Z
zardi
7 May 2020 12:32
I assembled Brimnes using regular wood screws instead of plastic wall anchors. This provides greater stability. However, you need to be careful not to use screws that are too thick, as the material can easily split.
danial60
8 May 2020 14:47
To provide a comprehensive answer, I will explain the assembly of the Ikea Brimnes in more detail and discuss possible alternatives.
First, it is important to know that Brimnes parts are mostly made of MDF with a melamine coating. This should be taken into account when choosing fasteners, as using the wrong screws or anchors can cause the material to crack.
The original assembly uses wooden dowels and small screws to join the individual parts. This method is practical and corresponds to the furniture’s price-performance ratio, but sometimes it lacks the necessary durability under heavier use.
User alternatives:
- Metal brackets and L-brackets can be installed underneath or behind the panels to relieve stress points.
- Using longer coarse-thread screws specifically designed for MDF to ensure better grip.
- Fastening screws through the furniture piece rather than only into dowels, if the appearance is not an issue.
- Optionally, pre-drilled recesses for mounting brackets can be added to make the furniture more stable.
The goal of these alternatives is to increase durability, especially for heavier use such as in family households. It is important to pay attention to the exact dimensions of the original parts and make modifications carefully.
In conclusion, I recommend clarifying whether you prioritize sturdiness or quick assembly, so you can select the most suitable methods accordingly.
I am curious whether you see primarily stability issues with the original assembly or if you want to reduce complexity?
PRA59
8 May 2020 16:17
danial60 schrieb:
I am curious whether you mainly see stability issues with the original assembly or if you are more aiming to reduce the complexity?
Thank you for the detailed response. For me, stability is the primary concern. I am worried that the original dowels might not be strong enough over time, especially with frequent opening of the drawers. Assembly complexity is secondary as long as the furniture remains stable in the long term. Has anyone here modified the Brimnes themselves or reinforced it with different fasteners? Does anyone have experience with metal reinforcements or alternative screws?
