ᐅ Are there alternatives to IKEA Brimnes for DIY projects?
Created on: 27 Jan 2018 08:43
nertil
nertil
27 Jan 2018 08:43
Hello everyone, I am currently considering starting a DIY project using the IKEA Brimnes system as a base. However, I am wondering if there are alternative furniture lines or individual modules that are equally suitable for DIY projects or possibly even more adaptable? My main goal is to modify the structure or customize the piece with individual inserts and materials. Are there any recommendations or experiences in this forum regarding alternatives that offer better workmanship, more versatile combinations, or more modular approaches? Thanks in advance for your advice!
KIN42
27 Jan 2018 11:07
The question is quite reasonable and well formulated.
While the IKEA Brimnes system is popular, there are other options in terms of material thickness and flexibility. For DIY projects that require adaptability, I recommend furniture series with clear basic structures and sturdy frame elements, such as the "Platsa" range from IKEA.
This system offers modular individual components that are easier to reconfigure and compatible with versatile interior fittings.
Additionally, craft-oriented hobbyists should consider building basic frames themselves using plywood sheets or construction timber to gain maximum freedom – although more labor-intensive, this approach offers unlimited customization possibilities.
Anyone looking for alternatives should clearly define their project goals. If the aim is to have the most flexibility and individualized design, Brimnes is not the optimal choice, even though the price may be tempting.
GUSTAVO56
28 Jan 2018 14:33
I would like to add more detail to the already good assessment by KIN42. Choosing an alternative to IKEA Brimnes for DIY projects largely depends on the requirements for stability, material, and adaptability.
First, regarding material quality: Brimnes is known for its relatively thin particle boards, which can be a disadvantage under heavy use. A recommended alternative is the IKEA system "BESTÅ." Here, the boards are thicker, the units more stable, and the components widely combinable. In addition, there is a larger range of doors, inserts, and accessories that can make the DIY project more attractive through diverse modifications.
From a technical perspective, the assembly should also be considered: Brimnes has fixed points that make restructuring difficult. In contrast, systems like PLATSA or BESTÅ allow a more flexible design through modular individual cabinets.
My advice for those who want to be truly creative is to use multiplex plywood or MDF elements as a base and build simple frames yourself, to which IKEA modules or doors can then be adapted. This completely bypasses the limitations of the predefined dimensions.
Finally, a question for you: Do you primarily want to modify furniture or build something entirely new yourself? That would help narrow down the advice in the forum.
nertil
29 Jan 2018 09:12
GUSTAVO56 schrieb:
One final question for you: Do you mainly want to modify existing furniture or build completely new pieces from scratch? This would help tailor the advice in the forum.
Thank you for the clarification; that is indeed important. My goal is to use existing furniture pieces as a basic framework to build upon, adding custom elements like illuminated glass shelves, drawers, or organizing inserts. A complete rebuild is too complex for me—I’m looking for a base with consistent dimensions to work from.
Durability and stability are very important to me—especially regarding hinges and load capacity—and, of course, a clean appearance without too many visible screws.
Based on your knowledge, are there any models better suited for extensions than Brimnes?
LAURE-TA
29 Jan 2018 17:25
Here is a structured response to the question: “Are there alternatives to IKEA Brimnes for DIY projects?” and in particular, regarding your additional requirement to create custom built-ins with a sturdy base:
- Basic foundation: Brimnes is designed more for simple standard furniture that is affordable but often made with very thin panels and basic joining methods (dowels, cam locks). This often limits later modifications because the structure is not robust enough.
- Alternative recommendations:
- BESTÅ from IKEA: Offers sturdier carcasses, thicker panels, and a wider range of accessories such as doors, drawer inserts, glass sliding doors, and lighting options. Ideal for built-ins with higher load capacities.
- PLATSA from IKEA: Highly modular and versatile, with stronger components that can be easily reconfigured using clip mechanisms. It is easier to add intermediate shelves or new compartments here.
- Custom-built components as supplements: For targeted adaptations, especially for built-ins made of wood that you can manufacture yourself, I recommend materials like multiplex plywood or MDF with a thickness of at least 15 mm (0.6 inches). These are excellent for building stable shelves, drawer boxes, or racks.
- Points to consider during implementation:
- Hinges and fittings: Use high-quality single-hole or cup hinges that allow adjustment after installation.
- Load-bearing capacity: Calculate the load of your built-ins and select suitably robust materials.
- Appearance: To avoid visible screws, many opt for drawer slide systems and concealed fittings.
Summary: If you want a modular and sturdy base for remodeling and expansion, the IKEA BESTÅ system is the best fit. For maximum customization, self-made wooden components can be added as supplements.
I hope this helps with your planning!
