I plan to assemble an Ikea Hemnes shelf myself, but unfortunately, I am missing some of the original screws. Therefore, I wonder: Are there suitable alternative screws that can be used instead of the Ikea-specific cam or special screws for Hemnes furniture without compromising stability or design? Ideally, I am looking for advice on the best type, size, and material of screws to use as replacements, and whether standard screws from a hardware store can be used or if there are specific technical requirements that must be considered. I look forward to your experiences and recommendations regarding appropriate alternatives, whether in terms of load-bearing capacity, fit, or potential risks when using non-original screws on Hemnes furniture.
Marcellela5 Jul 2024 20:34For Ikea Hemnes, I recommend M6 screws with a metric thread as replacements. Make sure to get the right length (usually around 40 mm (1.6 inches)) and choose material made of galvanized steel. Screws from hardware stores often work, but pay attention to the correct thread profile.
The original poster asks:
"Are there suitable alternative screws that can be used instead of the Ikea-specific cam or special screws for Hemnes furniture without compromising stability or design?"
Here is a brief guide:
- Ikea often uses screws with metric threads (M6 or M5) for Hemnes furniture, so it is recommended to choose the exact same size and length.
- Material: galvanized steel or stainless steel is best, as these are corrosion-resistant.
- Specifically for the connection: use screws with the same thread type and length to ensure proper fit.
- Screws from hardware stores can be used if you are sure they have the correct thread profile and hardness.
- Be careful with special screws that have unique head shapes: replacing them with a standard screw may affect the look or function.
Conclusion: Use M6 metric screws with the appropriate length and corrosion protection—this will maintain stability and appearance to a large extent.
Jensson schrieb:
IKEA often uses screws with metric threads (M6 or M5) for Hemnes furniture, so it is recommended to choose the same size and length.This is a good summary. Additionally, the following points can be made:
- IKEA also frequently uses special connecting fittings with lamella bolts or cam screws, which are difficult to replace individually.
- When selecting replacement screws, load capacity ratings should be taken into account, as Hemnes furniture is made using wood panels of medium-density fiberboard (MDF).
- The optimal screw length is approximately 40 to 50 mm (1.6 to 2 inches), depending on the wood thickness and type of joint.
- Using fine-thread screws is advisable because they provide better grip in MDF.
I strongly recommend choosing replacement screws that are neither too short nor too long to avoid pull-out or warping of the furniture parts.
Ladiron schrieb:
Are there suitable alternative screws that can be used instead of the Ikea-specific cam lock or special screws for Hemnes furniture without compromising stability or design?It’s best to replace the cam lock screws with M6 eye bolts or metric machine screws with washers. This maintains stability and the parts are widely available.
